Is that a 1/2” to 3/8” to 1/4 inch stack of adapters?
The other 1.5 gallons is in the engine block. You aren't going to get it out easily. This is how it is with any car.Well, I was trying to get more leverage.
That vent plug will never ever vent. I have to accept that...
But again, with the sensor out, it shouldn't make a difference. Still doesn't explain why that other 1.5 gallons just stayed in there.
Next time, I may put the rear wheels on ramps.
...which caused stagnate water, which caused corrosion which caused leakage which caused replacing the heater core...Our cars constantly circulate coolant through the heater core, some older cars used a heat valve that blocked it off when not in use.
Coolant gets acidic over time whether it’s circulating or stagnant, it’s good practice to change it every few years to prevent it no matter the system....which caused stagnate water, which caused corrosion which caused leakage which caused replacing the heater core...
Check mark that.... 2-5 years as I remember reading (or was it 5-8?). Worse (shorter end of cycle) in humid climates I think I read too.Coolant gets acidic over time whether it’s circulating or stagnant, it’s good practice to change it every few years to prevent it no matter the system.
I’m a 2-5 follower myself(I’m actually a little overdue). The rule of thumb is interesting, electrolysis occurs because of the coolant being in contact with dissimilar metals(eg iron and aluminum) so I always wondered if there’s a different rate of it occurring when the heads/block/radiator/heater core are all all aluminum vs. an iron/aluminum combo. I guess I could check with my multimeter but I don’t really want to know right now lolCheck mark that.... 2-5 years as I remember reading (or was it 5-8?). Worse (shorter end of cycle) in humid climates I think I read too.
I think I am due on the Town Car.
You can always do a old school cooling system flush with the garden hose. Flush it till it comes out clear, then close everything up and refill with antifreeze. Be sure to turn on the hearer so you flush the core as well. Done it for years on all my old cars. You'd be amazed how nasty stuff comes out sometimes.... especially in the block.It is difficult to completely drain the entire engine. I'm sure the block has plugs on it somewhere, but I'm also sure they aren't easily accessible. I'd say you are doing alright getting 1.5 gallons out. When I do coolant drain and refills I just drain the rad and maybe pull a rad hose, but you'll never get everything out. You can also treat it like a partial trans drain and refill and repeat the same procedure in a week or two.
I've been getting my traditional green coolant at NAPA. Seems to be in stock there. All of my rigs run green so I stay stocked up.
