- Waterloo, Iowa
- 1991 Mercury Cougar LS 5.0
I bought mine at Menards few weeks back, so assume HD and Lowe's have them also. HF does not have a 36mm last I checked
UPDATE:
So, what is the best way to clean the wheel assembly without losing the alignment marks? I would really like to get all of the caked on brake powder, grease, etc and look like the attached pic... (as if).
I didn't read the manual right then. They said and showed making a mark on the part I showed. I will look again.There are no alignment points on the knuckle, only the rear LCA bolt to IRS cradle for toe and the UCA bolt to IRS cradle for camber alter alignment. On the spindle side go to town with the wire wheel et al
Mine looked like burnt potato chipsSo clean... so little rust...![]()
Eu. I hope it didn't smell that way....Mine looked like burnt potato chips![]()
I figured using engine paint that is impervious to most automotive chemicals should hold up against peeling, chipping and over all getting to grungy.I really half assed the paint prep on my rear calipers too, I didn’t even clean off the rust besides removing the scaley bits. 10+ years they’ve held up!
I was trying to figure out how I could use this square hunk of junk into some kind of projectile....I hate that magic cube of death. I bought one of those caliper retract kits with LH and RH jackscrews years ago after fighting with that stupid cube thing on a couple of sticky rear calipers. Never again. One of the better tool investments I've made.
