Thank you! That confirms my thoughts.
My idea was to bypass the cornering relays when DRLs are not in use. That's where I made my mistake.
The reason I wanted to bypass them was because I don't want to wire a sort of unintended sequential effect where the outboard turn signal first lights up noticeably before the inboard turn signal. I mean the outboard lights are directly connected to the flasher circuit whereas the inboard lights depend on two relays. I know I'm talking about milliseconds here, but with LEDs that may actually be perceivable.
Meanwhile, I just had another idea: simply take an entire DRL module from a car equipped as I want mine. 98-02 Camaro comes to mind.
