- Oct 2, 2023
- New Mexico
Hey,
So, I put a new window motor in a while back and ever since then, the window got worse and worse to bring it down. Up is not bad I pulled the motor out and found that the motor I got from RockAuto was never greased inside, just the gear housing. I greased it up and made sure it worked, put it in the window still have about the same issue. I have to wonder if it is either the window regulator or the motor is just crap. You would think going down would be easier than moving the window up.
Before I replace the motor, I was wondering if any one else had this issue and found the problem to be different than just the motor. My manual had little to say about diagnostics for this issue. Oh, and yes, I did regrease the rail joints of the regulator. They are not dry.
Thanks!
Thanks!
