Factory Exhaust Info
Status
Not open for further replies.
theterminator93
Staff member
North Ridgeville, OH
    Exhaust systems on the MN12 varied between trims and model years. The exhaust systems for a particular engine for 1989-1991 model vehicles and 1992-1997 vehicles are essentially identical. The main change was a result of a redesign of the gas tank for the 1992 model year which allowed the exhaust pipe to flow under the tank rather than around it.
    All vehicles are equipped with 3 catalytic converters, one on each bank (side) of the engine and a third at the Y-pipe. 1989-1995 model vehicles also have a resonator after the third cat. A single pipe carries exhaust under the drive shaft and behind the differential. NA V6 exhaust exits through a single muffler on the driver's side. SC V6s and all V8s have another Y-pipe behind the differential that feeds dual mufflers.
    Pipe diameter is 2". On SC and V8 vehicles, diameter for the single pipe segment from the 3rd cat to the Y pipe at the differential is increased to 2.25". Diameter reduces to 2" again after the Y pipe to the mufflers.
    Status
