I've replaced all my front suspension components recently and when I go over bumps, I hear a strange rattling sound. I've checked for loose components with the suspension both loaded and unloaded. The only thing I can find is that when I grab the metal portion of the brake line and shake it, the caliper moves slightly and makes a bit of a sound. The passenger side caliper does the same and is even louder. The caliper bolts and the caliper bracket bolts are all tight.
Should the caliper be moving enough to make a noticeable noise? It sounds similar to what I'm hearing when I hit bumps.
It's surprising that whoever put in the new pads figured out to twist the rear pistons back in.
