Front Suspension Parts List
Bill H
1st Gear Poster
Gulf Shores, AL
94 TBird
Made some progress. The Mevotech site was a big help, but I have to go through Summit Racing website to order.
Will have more later but, here is what I have so far to start with.
I’m clear on the needed parts. Below is a link I used on Mevotech site. It lists Supreme and Original Grade brands. Let me know if there is a preferred brand or source other than these.
UCA
GK8596 - L
GK8598 - R
($30 ea)
LCA
GK80053 - L
GK80055 - R
($40 ea)
Rack Bushings
GK8263
($12)
Strut Rod
GK8659 - Front
$32
GK8680 - lower
($20)
Heres a thread for the Lincoln
Day job, and house projects keep me distracted, but small update:
Front end links, LCAs, and UCAs are here.
The LCAs from Mevotech had zerks fittings - the picture on Summit.com is incorrect. I wanted sealed units.
I ended up with TRW JTC1518 and JTC 1586 from Amazon (cheaper). They came powdercoated which was a nice adder.
Still on parts acquisition and waiting for weather to cool off. My shop is not insulated or climate controlled (yet)
Need to finalize strut rod bushings next.
I need to get back under the car to check out rear end links and bar bushings.
When I bought my front end parts labeled as "Famous Parts" brand from RockAuto, they turned out to be Mevotech. Nothing has fallen off the front end yet... give it another 20 years and maybe there will be some issues...
I wanted sealed ball joints and those had zerks fittings. They were fine, just personal preference.
The ones with zerts usually last longer, you can actually grease them. I personally think sealed ball joints and tie rod ends are useless, they usually never have enough grease in them and then they fail prematurely.
I partially agree with this, however most people over grease them which then breaks the seal allowing in contaminants, then fail prematurely.
The best ones have changed vendors several times over the years. Raybestos, acdelco, now mevotech. The gold ball joints and blue poly boots are the tipoff.
The ball joints are replaceable, and fit a bunch of cars.
Oh really? I was wondering about that, I have the control arms with the upper and lower ball joints being replaceable, but I was wondering replaceable with what, exactly? I was expecting some weird-ass modern Ford specific version that would be hard to find 5 years from now. Is there a name or part number for this standard? Or is it just obvious to whatever mechanic might need to replace them?
Ah, interesting, that's for both upper and lower I assume. I should buy a few of those. I was wondering if they'd made them some standard size so that there would be options for replacements, but then I remembered that they made a big deal about sintered metal bearings and I'd want the greaseable version, anyway. So it's them or nothing.
sintered metal bearings and grease fittings are what you want.
Lube all the fittings each oil change, and you can get 250k mi out of them.
Is there a rubber bushing option for the rear strut rod bushing at the arm? If so, toss me a bone with the link.
I’ve seen the thermoplastic ones. Was hoping for rubber at reasonable price. I’ve missed the intel on this one somehow.
SCP has rubber for $85. Seems a little steep.
The ones I took off were not that bad. The fronts were end of life.
The rear ones hold up perfectly fine in thermoplastic
