Holes?!
Ericv8thunderbird
Massachusetts
1994 Thunderbird LX
Since the weather hasn’t been all that great lately I figured I’d get a head start on getting ready for my SVO supercharger.
I bought an Autometer Wideband gauge and need to run this plug from the inside of the car to the outside. Before I go tearing up my interior, does anyone know if there is a grommet under the center console or driver side floor I can run this huuuge plug through?
If you look in Joe’s first picture, just below the center of the dashboard on top of the transmission tunnel is a round grommet. If you pull that out and cut a slit in it, you can put the connector through the hole and slide the wiring through the slit back into the grommet.
I used one of the grommets in the lower A pillar area and just snaked the cable through the kick panel into the interior. Least intrusive way I could think to do it
No easy solutions. One of the reasons when I installed NOS factory driving/fog lights I used a wireless controlled relay to be able to turn them off and on.
