Kooks EGR fitting
XR7-4.6
Administrator
Staff member
Roselle, IL
    1994 Cougar XR7 DOHC TR3650
    So I’ve run into a bit of a snag. I’m to be running 4V Kooks headers and don’t have much choice but to delete EGR unless I come up with a custom tube to fit my combo. I bought a block off set this week but the cap for the header is way way to small for the kooks, it fits my existing manifolds fine so it seems the marks use a much larger nut/tube?
    I tried seeing if a 3/4” plumbing cap might fit but it’s just on the cusp of too small as well. Anyone else with 4V headers run into this, solutions? Only thing I can come up with is find a used EGR tube to salvage the nut from and weld it closed but finding one is it’s own challenge these days.
    Any chance it's a metric thread ? 🤔
    If you can get the first couple threads to take its just going to be a mechanical seal anyways.
    I was wondering if it might be metric but measuring/counting the threads it sure seems like it’s 3/4 x 14 like the pipe cap, but I can’t even get it to catch
    (Last pic was .5” on the calipers)
    So after using my triangle file to clean up the end threads a bit I was able to get the cap started, but this is about as far on as it goes, seems like about two threads. Mechanical seal it is!
    The EGR tube fitting should be the same as any other ford of the era. I have an old 95 2V tube here I can send with the steering shaft if you want to weld it closed. I've hung onto a few of the old 95 tubes for an occasion such as this.
    It's definitely not. I threaded the blockoff I ordered(pictured in the first post) onto both my Cobra headers as well as the stock 94-97 manifolds from my car and it fits perfectly well, same as the EGR tubes. These 4V Kooks and I presume Mark VIII manifolds for some unknown reason use this larger fitting which in my guesstimation is at least 1/8"-1/4" bigger
    If you want to seal it 100%; use some X-pando pipe joint compound .. it's what I use on threaded joints for high pressure steam systems. 😉
    I think that's exactly what ill do! I'd like to pick up another cap to see if this one is cut weird and/or heat it up to see if I can get a few more threads engaged but I think this will work. Just like spending $10 on feeler gauges to shim my $1,700 cams, I'll be spending $20 in plumbing caps and goop to seal these $1,000 headers lol
    I have NPT pipe caps and some xpando I could send you. Spending $15 on a can of compound to make 1 joint seems like a waste. I'm just thinking its a metric thread ( the Mark manifold uses a thread to thread adapter on the EGR )
    In the past i have used a stock nut with a penny installed to block it off. Works great and only costs a penny. Or a penny-sized piece of steel might last longer
    I did the penny block off on a 95, the penny melted within a week lol
    Typically this would have been a flared nut for tubing ( egr ) .. determined by the OD size of the pipe itself. Maybe SAE threads .. not the same as NPT.
    Questions: Are the threads on a taper?
    What is the od?
    What is the thread to thread spacing?
    The fittings on the trans are bpst, british pipe straight threads. There is also npst, national pipe straight threads.npt is national pipe taper. AN is a straight thread, english based. All are different.
    What is the od?
    1.05” od, threads are 14tpi(I measured 7 in a half inch). That’s why I thought the plumbing cap would fit.
    Are these caps ever tapered npt? it’s possible I just bought the wrong one but there’s nothing on the packaging that says it
    I forgot to ask is that compound hard to remove later on? Right now I don’t have the time, fab skill or patience to do it but down the road I would ultimately like to cobble together an EGR tube
    I can tell just from looking at the picture that those aren’t the same thread. That cap most likely is tapered pipe thread, and the thread on the header will not be tapered. 1”x14 is a standard thread pitch, so I would buy a 1”x14 nut, weld a plate over the end, and just tighten that down on the bung.
    cap you have is tapered, fitting is straight, cap is expecting the end to be smaller. it's npst
    Take it outside and try the hose. thats .75 straight
    A stainless dishwasher hookup would work,
    Yeah it's hard to remove, not permanent. It takes a bit of effort to get it to unthread if it's going to be in vehicle later .. 🤔
    A stainless dishwasher hookup would work, but you'd have to yank the rubber seals
    I was changing the only on my 97 E350 today. And because of this conversation I looked at the EGR tube. On my 5.4 it is much larger than the Tbird size Egr nut. Maybe you can get one from an old 5.4.
