Generalee0527
- Jan 4, 2024
- SW GA
- 97 Tbird, pbr front brakes, Sport edition 4.6 w/ 369k total miles by me the one and only owner.
Well it sucks to have coolant leaks in the dead of winter. No fun working on it as it has to be cool to work on it but the wind is a continuous irritant and you can't ignore it and keep going. Since I tolerated no heat last winter when I by-passed the core as I had just replaced the intake gaskets to stop a leak under the intake. So here I am now adding water/coolant little at a time since replacing the heater core in Sept. So I noticed it was leaking g at the overflow tank cap. New cap, started leaking at heater core connection. Tighten clamps a little more. Now I can't drive more than 5 miles after tipping off till low coolant lite comes on and the tank is almost dry. For the life of me I can't seem to locate it. Put a half bottle of bars stop leak in and no help at all. Replaced t-stat o-ring as it appeared to leak there for a time but now is tight. The other day I thought I saw a wet spot on right front under the alum crossover. Not much but was wet. When I check under car it is dripping from the inspection plate at trans and block . I am beginning to wonder if there is a bad freeze plug as I haven't found the source. Seems it only leaks after shut off and cool down when I wouldn't expect it. I am ready to start beating on things w/ my bfh!
