you can upload it to YouTube and post the link, I don’t think videos can be uploaded directly to the forum
it happens across the whole circumference of the turn, meaning anywhere the steering wheel is, not just in a certain position.Yeah I definitely see/hear the pops, are those specific areas where the play is most pronounced? I’m still leaning u joint or loose hardware on them, I don’t think it’s the rack itself, I’d lean towards defective tie rod ends first
The wheel was not removed, good thought though.Did you have your steering wheel off? Because this sounds just like it does when I remove steering wheels in the junkyard: when the bolt is slightly loosened, and then the wheel moves up a bit on the shaft.
Just a thought.
