- North Ridgeville, OH
When I replaced the PS pump on the Mark 2-1/2 years ago, the seal inside the nut (not the teflon seal, the unserviceable O-ring inside) at the pump got mangled a bit and has had a very slow leak since. The underside of the K-member on that side of the engine has had a thin coating of PS fluid (ATF) on it and I catch a whiff of it burning off the exhaust every once in a while. The leak is so slow I've yet to notice much of a change on the fluid level in the reservoir, but it still bugs me and I finally bought a new pressure hose off RA ($4 in the clearance bin!) last week. The question now is how long will I procrastinate until I install it...
This is new territory for me, but I've repeatedly read tales of how rack replacement is a nightmare because of how hard it is to get at the pressure hose at the rack. If all I'm doing is replacing the hose without needing to remove the rack, how much pain and suffering am I really signing up for? Can I do it in an afternoon without K-member lowering or lifting the engine?
