Radiator fan connector
bowez
Nashville
93 SC
Looking for a replacement +30A connector to replace both ends for my radiator fan pig tails.
Not requiring stock just a good replacement, as this was one item that didn't survive the theft.
Best of luck. I bet someone out there has one laying around their parts pile.
I'm all for even using an aftermarket weather tight connector.
You could get a automotive connector set that has the rubber seal, it just won't look the same and you wil need to do some wire cutting and soldering to replace the OEM ones. Just a thought.
I went on eBay and typed in 1993 ford super coupe fan connector and a bunch of connectors came up. I could ask over at TSTSNBN or other sites that someone has a scrap 89-93 SC or similar that uses the extra connector.
Any opinion on Metri-Pack 630 series or Deutsh connectors?
Those connectors always get brittle and crack. Unless you have one laying around, I would suggest either just using weather-tight spade connectors, or go to a junkyard and find any 3-pin connectors with heavy enough gauge wire to use and splice it in.
Hence the question about Metri or Deutsh.
Somewhere I have some 30A male and female spade type quick disconnects. I saw them in the garage while I was working on the stereo. I'll look tomorrow; I can mail those. I have 10 awg wire, but it won't go in an envelope,lol. You're in nashville now?
Think I've settled on the Metri-pak 630 now does anyone have a suggestion on wiring?
Looking for just a few feet of BLUE, Orange (in a perfect world would be with brown stripe) and Black. Either GTP or S/GXL. Any input on gauge 12 vs 10, it's only like 3-4 feet at most total run include the existing factory wiring. I can find Blue and Orange in 12gauge but not 10 least not without buying 1000' of spools.
