I realized last night that I have the cleaner fluid cannister upside down. Air is lighter than fluid so the solution has to be at the exit point, meaning the gravity has to play its part and the fluid needs to be at the bottom. I will hang the cannister upside down from the way it is in the pic so the fluid is at the bottom.Just make sure you’re smoking while you’re cleaning these.
But seriously, I like the set up.
Check that and will do! I almost won the Darwin award once when I locked myself in a freezer for 10 days by accident.... or was it an accident? Last thing I remember is leaning over for some jerky and BAM and I woke up in the freezer, door locked. That crazy wife of mine! Always playing pranks on me.Just send your real name to a mod, That way if you earn a darwin, we'll be able to attribute it correctly.
T
One of my dumbassed friends walked into my garage, as I'm mixing rocket propellant; It burns like magnesium."I have a gun. I will shoot you if you set me on fire!"Just make sure you’re smoking while you’re cleaning these.
LMAO! Thank you, that was funny!One of my dumbassed friends walked into my garage, as I'm mixing rocket propellant; It burns like magnesium."I have a gun. I will shoot you if you set me on fire!"
Dang, how did you know? Like I always say to my wife "don't you understand physics?" when trying to describe something as simple as a dishwasher.White Lincoln must be an engineer, we tend to overthink things.
<chuckle> 9 volts works?I clean fuel injectors with brake clean and a 9v battery? This method seems overly complicated to me
The kit comes with the filters, o-rings and washers. Everything to get it running like new. the old filters are usually crap anyway and do tend to get damaged when you pull them out.So do you clean the filter separately? Or do you replace the filter with a new one?
Yes, the screw must be short and it needs to screw in snug or it will pop out under pressure or if too long, the tool will not enough force to pop the filter out. the older the injector is, the more the filter has become entrenched in the injector. I will see if I can get the screw thread size I used.I use a proper sized screw to remove the old filters
![20240818_152129[1].jpg 20240818_152129[1].jpg](https://forum.birdcats.com/data/attachments/7/7179-3ab1bc1c507a8eead83f3ecc05dede4f.jpg?hash=OrG8HFB6ju)
Why does the screw need to be short?Yes, the screw must be short and it needs to screw in snug or it will pop out under pressure or if too long, the tool will not enough force to pop the filter out. the older the injector is, the more the filter has become entrenched in the injector. I will see if I can get the screw thread size I used.
In the pic above of the injector with the screw and washer with a Panel Clip Plier, the distance the two parts of the Panel Clip PlierWhy does the screw need to be short
Yeah, you must be stronger than I am and braver that you won't screw up the table top...A 310 sheet metal screw has coarse treads, and you're hooking a thread under the metal ring at the top of the filter, and popping it out of the groove it snaps into. Putting them in, I press them on a table.
I was able to use a screw and pull it out by hand. Longer screw helps in that situation. Whatever way works man as long as you got them outIn the pic above of the injector with the screw and washer with a Panel Clip Plier, the distance the two parts of the Panel Clip Plier
In the pic above of the injector with the screw and washer with a Panel Clip Plier, see the distance between the electrical connector of the injector and the large washer? The shorter that distance is, the more force you can apply on the plier to pop the filter out. They are stuck in there, believe me. When you put new ones, you have to press them in, they don't just pop in.
Hope that helps.
Amen brother....I was able to use a screw and pull it out by hand. Longer screw helps in that situation. Whatever way works man as long as you got them out
