SRS (Air Bag) Codes
Status
Not open for further replies.
theterminator93
Administrator
Staff member
North Ridgeville, OH
    1997 Thunderbird 4.6, 1998 Mark VIII LSC
    Code Meaning
    12 Low Battery Voltage
    13 Air Bag Circuit - Shorted to Ground
    14 Primary Crash Sensor - Shorted to Ground
    21 Safing Sensor - Not Mounted to Vehicle Properly
    22 Safing Sensor Output Circuit - Shorted to Battery Voltage
    23 Safing Sensor Input Feed/Return Circuit - Open
    24 Safing Sensor Output Feed/Return Circuit - Open
    32 Driver-Side Air Bag Circuit - High Resistance or Open
    33 Passenger-Side Air Bag Circuit - High Resistance or Open
    34 Driver-Side Air Bag Circuit - Low Resistance or Shorted
    35 Passenger-Side Air Bag Circuit - Low Resistance or Shorted
    41 Primary Crash Sensor #1 Feed/Return Circuit - Open
    42 Primary Crash Sensor #2 Feed/Return Circuit - Open
    44 Primary Crash Sensor #1 - Not Mounted to Vehicle Properly
    45 Primary Crash Sensor #2 - Not Mounted to Vehicle Properly
    51 Diagnostic Monitor Internal Thermal Fuse - Open Due to Intermittent Short to Ground
    52 Backup Power Supply - Voltage Boost Fault
    53 Primary Crash Sensor Circuits - Resistance to Ground, or Internal Diagnostic Monitor Fault
    Rapid Continuous Flashing of AIR BAG Readiness Lamp - All Primary Crash Sensors Disconnected
    If you plan to work on your airbag system, exercise extreme caution. Personal injury may result if you accidentally deploy an air bag. The airbag system is live all of the time - it is not switched on and off by the key. There are also backup power supplies. The 1992+ systems will discharge in about one minute after disconnecting the battery.
    Never attach a self-powered test light to any part of an airbag system. If you want to work on the system, acquire and review a manual that covers servicing of the system. Examples are the Air Bag System Diagnosis training manual from Ford, as well as the shop manuals from Helm.
    Original material adapted from www.shotimes.com/SHO3airbagcodes.html.
    Status
