Is there a definitive action plan on strut rod bushings since the OEM ones are gone? I know the thermoplastic ones don't last (didn't on the wife's 5.0). What's the best option on replacements and procedure now?
I also considered these before going with the lincoln continental bushings. claims to be natural rubber.. not sure..Is there a definitive action plan on strut rod bushings since the OEM ones are gone? I know the thermoplastic ones don't last (didn't on the wife's 5.0). What's the best option on replacements and procedure now?
I have the SCP front bushings and can confirm that they're noisy as all hell if it's the least bit cold out. I eventually need to figure out what to do about that.
That reminds me, are the sleeves/ washers unique or did i just get swindled for a set of 40$ bushings??SCP poly bushings are repackaged energy suspension bushings for a 61 continental
I genuinely wondered if i was paying for the instructions or hardware or just getting clucked
The energy suspension Continental sleeves need to be hogged out a little bit to fit over our metric strut rods and they don’t come with washers, so the SCP premium does have some value to it
That said I was able to hog mine out using a brake cylinder hone and the very same washers in the SCP kit are less than $10 from your local Ace hardware
Too cold? What to do about that? Move out Canada!I have the SCP front bushings and can confirm that they're noisy as all hell if it's the least bit cold out. I eventually need to figure out what to do about that.
this does make me feel a bit better about the purchase, and bill seemed to know his stuff, the shop that installed his parts didnt
Did you lube them during the install? Mine are silent and I haven’t relubed them since I installed them. I used dielectric grease
No idea: I have no mechanical knowledge / space to work, so I rely on shops to do what I need done, sadly. I hope one day to have an actual garage with space, but in the meantime I'm stuck. Is it possible to go and ask them to take the bushings out to grease them once they're already on, or should you might as well replace them at that point?
