Grog6
Moderator
- Harriman, TN
I have a non-mn12 question. My sis's flex ac blower died, Think it's the resistor module?
Yeah they squeak unless they're well lubed.I'm also wondering if these poly bushings are prone to squeaking?
Thanks. Greeeaaattt. I put zero lube on them even though I have a full tube of silicone grease. There were no instructions in the box and I looked on the site. Couldn't find any there either. Don't know what to do now. Damn sure ain't taking them out... Did it while the subframe was out. Now it's in.Yeah they squeak unless they're well lubed.
When I redo mine sometime this year I'm getting these, and lots of silicone grease.Iput zerk fittings on the poly stuff I did on the mark arms on Lazarus.
Now at least I have a goal to aspire to.So is being a "whore" a good thing? Why am I embarrassed? Wasn't there a South Park episode about this?
Oh, I own a 5spd, it's just not in the car yetPost whore takes 1000 posts to achieve .. better get to work.
5th gear should be reserved for owners with actual 5 speeds; the rest of you only get 4.![]()
Omg I'm dying right now... I can picture Cartman going on and on about this.. lmaoSo is being a "whore" a good thing? Why am I embarrassed? Wasn't there a South Park episode about this?
Are these the same for the T-Bird panels also?Would anyone know a source for the rear reflector panel nuts? They are an acorn nut cover over a sheet metal trim nut. Only suitable idea I have found to replace is nylon acorn nuts, but they likely aren't deep enough, so if have to run a regular nut on first.
Yep, those are the ones.
Man, I'm glad I saved a lot of the the PMs from TSTSNBN!Yep, those are the ones.
Thank you!!!Man, I'm glad I saved a lot of the the PMs from TSTSNBN!
N620376S36, Green Sales is showing 19 in stock right now. I bought some years ago when mine were looking a little tarnished!
So does the bushing itself have a hole in it so grease can get to the bar or does the grease just get between the housing and the bushing? If the latter, then I can probably remove the housing while it's in the car and add grease. Otherwise, I suppose I'm screwed unless I drop the subframe again. It wasn't a terribly bad job on a lift but I really don't want to do it again...All the poly stuff I bought came with lube. After I added zerk fittings, I bought another smaller grease gun for silicone dielectric grease. Regular grease is bad for the poly.
I use copper grease on dissimilar metals, like aluminum to steel. I use it on my spark plugs to. Never had a frozen nut or bolt.NAPA's copper grease works well too. Used that with the Powerflex bushings on my old E46. Zero noise but you've got to cake it on there.
Junk yard! Just about any Ford around that year should have them.Would anyone know a source for the rear reflector panel nuts? They are an acorn nut cover over a sheet metal trim nut. Only suitable idea I have found to replace is nylon acorn nuts, but they likely aren't deep enough, so if have to run a regular nut on first.
I drilled thru the outer part of the control arm, thru the bushing, down to the level of the center steel pieces. With the zerk fitting in, it squirts grease out both ends. ~1/4 hole.So does the bushing itself have a hole in it so grease can get to the bar or does the grease just get between the housing and the bushing? If the latter, then I can probably remove the housing while it's in the car and add grease. Otherwise, I suppose I'm screwed unless I drop the subframe again. It wasn't a terribly bad job on a lift but I really don't want to do it again...
