rampagingsloth
If the car came from the factory with an AGM, get an AGM.
If the car came from the factory with a wet-cell, don't get an AGM.
It really is that simple.
That's interesting, why is that? I mean, at Costco returning the wiped out Optima battery for core I noticed some signage on the wall talking about how important it is for a modern car that comes with an AGM battery to get another AGM battery as a replacement. I went with a regular wet-cell battery to replace that Optima battery (more CCA, more CA) but does that mean that a car's electrical system is somehow optimized or designed for a particular type of battery? I had assumed that a charge was a charge, wouldn't matter where it originated from.
Big stereo's eat agm batteries. Liquid is better than gel.
I hadn't heard that though I wouldn't doubt it, all I'd heard (years ago) was that Optima batteries were powerful and useful for older cars that needed more juice. How do big stereos eat AGM batteries?
Regardless, as I said I went back to traditional battery for the replacement. I've noticed, by the way, that the car still shows a slightly lower charging on the Volts meter at idle (the needle usually now sits between the N and O of NORM), though not nearly as low as before, and it pops back to its usual place once the RPMs increase when I start driving (now between the R and M of NORM). I guess having a mauled battery that doesn't want to hold a charge for more than a day will reflect that in how the Volts meter is reading.
