- North Ridgeville, OH
Original post date 1/2/12
Okay, so this spring the bird's getting some trans goodies, with the expectation that next winter will bring ported heads and cams. I've done some looking around and I'm thinking about going with Nick's stage 2 PI head and stage 2P cams combo, with the modified valves etc. I'm hoping for a fun street toy; 280-290 RWHP is the goal.
The thought is to swap the heads and cams, keep the PI intake, and leave the stock bottom end be (I won't be pulling the engine). I've read some varying info on the durability of the stock bottom end when it comes to RPM though. I understand the stock crank should be fine in such a combo up to 7000 or thereabouts, here the worry is the rods. My question is if I'd be safe with the stock bottom end with such a H/C combo, and what a reasonable RPM limit would be such to keep things in one piece. I'm assuming it should be okay up to 6300-6500, but I'll be the first to admit I'm not the most knowledgeable on this topic.
That way you won't have to risk running your stock heads and cams all the way to 6500 rpm
3-4 I can see, but 2-3?
