I'l go thru the whole process. A press is really needed, but there are tools that can do it.
Front wheels. PBR calipers, either cobra(18"wheels required) or 2004 mustang gt. (Works with 15" wheels.)
2004 mustang gt hubs.14"mustang gt disks
Rear wheels: Dalke's relocation brackets for our calipers, Cobra rotors, Hubs for mustang with irs, New wheel bearing, new seal, 4 new rear hub nuts, quart of new brake fluid,
rear sequence is: press out stock hub. Remove bearing retainer, press out bearing, taking care not to bend the knuckle. Tapping it with a small hammer helps a lot. Press new bearing onto knuckle, replace retainer. Press new hub into bearing, supporting the bearing hub as it goes in. make sure there is grease in the bearing before you put the hub in. I'd do new axles in the back if they have any play. Turn the rear wheel as you tighten it. it will loosen up.keep toruing it to 100 ft lbs, turn, re torque, repeat. Recheck the torque, and when it holds thru a turning session, take it to 250, and rotate more. Recheck.
