Want to attempt PS pump rebuild...
However, I can't seem to get it apart! There is a stiff wire clip at the rear of the pump that looks like it will provide access to the pumps internals but I can't get it out. Anybody done this before?
I've rebuilt pumps, just not these. If you haven't already I'd clean it all real well. Scrub the clip with a small wire brush. Spray some PB blaster on it and let it sit a day. Then I'd suggest using a C clamp to put just a little tension on the rear cover that the wire clip it retaining. That should help relieve the pressure stopping you from removing the clip. Have some picks or smaller flat blade screwdrivers available when removing the clip to pic it out. Hope that helps.
There is a small hole on the side of the pump you use to push on the big lock ring, then you can simply work it out with screwdriver
Thanks for your post. Tried exactly that. Couldn't get the wire clip out and the amount that I preloaded the back cover increased the shaft end play by the same amount.
There is a small hole on the side of the pump you use to push on the big lock ring...
Hmmm. Interesting. I can't tell if one of your pics shows the location of the hole. I'm about to head to my shop, it's 45min. away.
Thanks for the tip.
I always wondered how to get one apart; I see what I did when I failed the line mod,loi. Those vanes were hitting the end of the fitting. That's just like a vacuum pump I rebuilt.
Our power steering pumps are wankel engines, lol?
Where does someone find a kit for this? Pretty universal?
It's just a centrifugal vane pump. You can usually only get seal kits, but unless it has seen some hard times, that is all that you need.
That's what I did with mine. If it has a lot of miles on it the shaft might have a grove worn into it from the seal and leak, mine didnt but the one from the explorer motor I had and took apart did. there's also a brass bearing that could be pressed out. Beyond that yeah, not much to it,
Well, I got one from Rockauto, however, after I got my pump all apart and cleaned and went to install thenew seals, I discovered that the kit I got is for a different pump. It's for the kind with the attached round reservoir. Looking for the right kit today...
After a quick online search I find that Autozone has a kit among others. Autozone's kit is $32. Even though the Rockauto kt was incorrect, it was about $13. I only decided to try to rebuild mine because the kit was so cheap. $32 seems a bit steep and I don't think I would go that route. The rebuild pump I got from RA was about $73 after core charge.
Getting a pump with an evo valve can be hard. I had the coil burn up on one.
I deleted EVO on mine, with 255mm tires the Cobra rack and extra caster dialed in having a electric assist reducer became kind of unnecessary.
FWIW my seal kit I bought from a seller on ebay for I think $17 shipped.
