- North Ridgeville, OH
The more buttons, the better!
...I mean, I was exaggerating. But to elaborate on my point, I really prefer A. the look of buttons, and B. the tactile feel of pushing a button vs. turning a dial.
What type of aircraft is this?
I take it you're in the right seat as copilot?
How many hours did you have to do, and studying behind it, to get this far?
Brandon, What are you flying with 6 engines?
As for cockpits, there are reasons why they are the way that they are and obtaining a private pilot license is a time-consuming endeavor, never mind a commercial pilot license, never mind all the additional training to be more than marginally competent, unlike going to your local DMV to get your comparatively "free candy" personal vehicle driver license.
because the blind drive....I can’t argue with A but I’m fairly sure the blind would have an easier time operating the knobs, which I’d say makes them pretty tactile . At least in the blower speed and blend settings; clockwise more speed/more heat/counterclockwise less speed/colder. The function selector is the least ergonomic of the trio but ironically it’s the one part shared between manual and SATC
Has anyone added carpet to the bottom side of the deck-lid? Could be kind of cool with a logo embossed in it.
As long as your not hearing a rhythmic click at idle near front of passenger side valve cover I would say your good. Mine has been doing the click for about 5k miles and I cringe listening to it.So this will be the first time for timing chains? So with my 87,000 miles as of now, it's not something I need to worry about anytime soon?
Took her back to the shop after already having 2 sets of strut rod bushings installed. This time around they were too loose instead of too firm..? They said they were going to try and retorque stuff and shim it worst case.
car is back home, steering feels infinitely better/ no clunk, and im anxious about purchasing my next set lol. Gonna go for some oem replicas the next time around
Clean! I did same with my camera wiring.And it’s done!
View attachment 16547View attachment 16548
And now to make these hideous wires disappear
View attachment 16549View attachment 16550
I’m wondering if I got the right slave cylinder, there seems to be a difference between the 4 cylinder S10 and the 6 cylinder s10.Very simple way to bleed the S10 setup. Remove the slave cylinder while leaving the line attached. This will allow the slave to fully extend. Now tilt the front of the slave cylinder downward, so that the line is the highest point, and push the piston all the way in, then let it come back out. This will push all the air up, the line and it will bubble out of the reservoir. Repeat the motion several times, then bolt the slave back in place and you have done. No special tools needed, no extra person needed, no brake fluid leaking in your face or on your exhaust.
Realy nice dash! I wouldn't mind modeling mine after yours.And it’s done!
Nice write up. Best of luck on your project, hope you resolve it.Yesterday was finally warm enough to get my exhaust bolted back up after pulling the transmission, again!
Remember how I mentioned that the clutch fork was hitting the bolt for the slave cylinder bracket I made, and I thought that was the issue of it getting stuck in reverse? Well, that wasn’t it.
I started up the car let it run a bit and threw it in reverse while it’s still on jack stands, and it got stuck on the first try.
I know it’s not an internal issue, I spoke with the guy who rebuilt the transmission and all thoes issues were addressed.
So, I started to do some research on the Chevy S-10 slave cylinders. Many people mentioned having a hard time bleeding them, they would bleed and bleed and bleed and still have air trapped inside.
My suspicions led me to believe that’s my issue. I cracked the bleeder and let it gravity bleed for about 10 mins, the fluid came out nice and steady at first, then after a couple minutes it trickled and came out steady again, this happened a couple times over the 10 mins I let it gravity bleed. I suspect there still some air trapped inside.
I did a little more digging on the interwebs and found this power bleeder on eBay, I ordered it and I’m going to give this a try. Hopefully this is it. Cause, if it’s not, I’m going to push the car off a bridge!
If it bothers you, you can try using the FL500s filter instead of the FL820s. It is a little thinner and longer than the 820, and much easier to get it in and out of the confined space in the car.I changed oil and rotated tires on my daily driver 95 xr7.....and yes, i still hate changing oil on this car.
