Iceman8.6
Newbie
The car is a 1997 TBird 4.6l all stock.
Having an intermittent engine turns over but no start issue. Checked for spark then fuel pressure first. The spark is working fine but there is zero fuel pressure at the Schroeder valve on the fuel rail. Did a voltage check at the Inertia Fuel Shutoff switch in the trunk and its reading roughly 6.5 volts. Pretty sure the fuel pump needs 12 volts to work.
Is it possible the fuel pump relay in the CCRM is getting worn out and sending half voltage to the IFS? I can feel and hear the relay in the CCRM working when holding it. This car has a lot of mileage on it(338000 miles)..
The battery is fully charged and turns the motor over easily.
