Clock
My clock has been misbehaving. It seems to reset to 12:00 every time I shut off the car. Do our clocks have backup batteries in them? I was thinking it would be redundant and cost more, but I have no other idea why it would behave as such...
Your thoughts?
Following since the clock in my 95 XR7 intermittently resets when I turn the car off. Also, the voltmeter rarely works. I assume wiring issues are the problem for both.
Any other issues? The clock uses key off power for memory while the volts gauge uses hot in run power (which the clock does too for powering the display, but not for memory). The only common denominator between the two would be the ground, but that has a whole bunch of stuff in the dash tied to it as well
No other known issues
Interesting. My voltmeter works...kinda but its flaky, sometimes reading discharge when it is charging...
My clock started acting up a few years ago. After the experience I had with my Town Car clock and trying to fix it, I bought a new one for the Cougar.. I bought it on eBay and it has not been a problem since.
Side note: can the clock be set to 24-hour format?
I do not believe so. I never saw anything in the paperwork or buttons you can change type of time. But I will look.
Update: I couldn't find anything about the clock being set to military time, but that does not mean it can't be somehow.
Anyway, $50 average on eBay for a new one.
