CDsDontBurn
I probably have the member page saved in my 2009 archive. Let me take a peek...
Edit - nope, not coming up.![]()
Why not utilize the The Wayback Machine then?
That is correct and makes it a b*tch to insert new core. Even when lathered w/ dawn detergent. I wound up cutting mine on side near fender to give more room as the core goes straight in according to the slot in box. Thankfully I've only had to do this once in 381k miles.The gasket is sandwiched between the firewall and the heater box and larger in size than the hole the core passes through.
Got a link to the article?Why not utilize the The Wayback Machine then?
I drilled a tiny hole into the bottom of the heater core housing. About another half cub of coolant came out.
For those of you who have done this, is there usually coolant pooling up in the evaporator housing? That seems to be the lowest point, but I'm not comfortable drilling into it. I'm worried that the evaporator is swimming in coolant.
If there was any fluid discharged into the evaporator housing it should have drained out the drain port through the firewall the same way excess condensation from using the A/C would.
I have to say that my A/C has never been this cold before. I'm guessing that, even with the blend door set at full cold, a 200°F heater core in the immediate vicinity of the airflow always caused some minor heating.
Yep, you can feel the heat from it through the vents with AC off and the temperature set to max cool too, it’s always warmer than the outside air being pulled in through the cowl. The HVAC in these cars leaves a lot to be desired
Just fix the heater core. The part isn't that expensive and the job isn't that hard.
getting improved A/C performance without functional heater core.
Where do you get this idea?
HVAC air always passes through the evaporator. Depending on the blend door setting, it may or may not pass through the heater core at all. Having it plugged off won't "improve" A/C performance.
IMO even with the blend door shut there’s heat from the core radiating past the blend door into the ducting what you get out of the vents isn’t as cold as it would be with a bypassed heater core. I would not at all surprised if there was a 5° to 10° difference out the vents at full blast.
Or if the weather up north doesn't come to you. It's been cold up here this winter, might get a break next week when temps get into the 40s.So yeah, this is how it's going to be this winter and for as long as I don't live any further north.
