Apparently it's an obsession...
Yes, I installed yet another shift knob.
The ideal shifter is really important for look and tactile feel. My favorite shifters are the gated styles (Mercedes through the 90s and Jaguars's "J-Gate"). I also love column shifters. But since all that would be way difficult to install, at least finding the perfect shift knob is an option.
Let's start with my shift knob history. I started out with the stock plastic unit in my base model Thunderbird:
Ergonomically, it's pretty much perfect, falls right into your hand, and beautifully reflects the asymmetrical, cockpit-style dash layout.
I began by experimenting with some wrapping and learned the baseball stitch:
The faux suede used here became dirty way too quickly, so that didn't last. Next was leather with contrast stitching:
My preference for real wood trim is no secret, and I finally found a wood shift knob that fit (with some internal modification).
The Lincoln LS carved wood unit was really pretty; however, I decided to remove it for two reasons: Ergonomically I much prefer a thumb button over the front button, and visually the entirely symmetrical shape somewhat clashes with the MN12 dash.
Nonetheless, I think it was a beautiful installation, especially with the custom chrome O/D button and the custom center piece of the 3-piece slider, which has the proper size hole for the exposed metal shifter rod.
So what's next? Well, I somewhat went back to my stock shift knob, but with a custom twist: I wanted to keep the exposed metal rod because I like that look; the stock plastic/rubber shroud is my least favorite part of the stock shifter. I also wanted to match the black stitching of my leather steering wheel (a lucky junkyard find).
Some sawing, stitching, cheap leather from Michaels, and a combination of my old shift knob with the short shroud from LS knob, and this is my new look:
I filled in the old O/D button hole with wood. The stitching mostly matches the factory look, though I also stitched all around the thumb button hole.
I'm very pleased with the new look; I think it's a great balance between the stock design and subtle customization.
