| Approx. Date | Approx. Mileage | Description |
| 11/2004 | 80,500 | Vehicle purchase Flush automatic transmission
 Replace front lower ball joints
 Replace front left upper control arm
 Oil change
| 8/2007 | 90,000 | Replace MAF sensor; Ford OE (NAPA remf’d) |
| 6/2008 | 99,000 | Replace right rear shock; NAPA Response Replace serpentine belt (NAPA)
| 8/2008 | 101,000 | Oil change: Pitt-Penn 10W-30 conventional; Fram PH-2 filter |
| 9/2008 | 102,000 | Replace front brake rotors, pads Replace right rear brake rotor, pads
| 1/2009 | 106,000 | Replace spark plugs; Autolite Platinum AP764 Sea Foam treatment thru gas tank and plenum
 Replace LR caliper; Ford OE (NAPA remf’d)
| 1/2009 | 106,500 | Replace headlight bulbs; 3850K Halogen |
| 1/2009 | 106,750 | Replace four tires; Firehawk Indy 500 (215/70) |
| 2/2009 | 107,000 | Left door lock cylinder repaired Power antenna repaired
| 2/2009 | 107,250 | Replace rear shocks; Monroe SensaTrac Replace front shocks/springs; Monroe Quick Strut (SensaTrac)
 Replace front right upper control arm/ball joint; Dorman
| 3/2009 | 108,250 | Clean MAF sensor Replace air filter; Fram
 Oil change; Motorcraft 5W-30 synthetic blend; Fram PH-2 filter
 Replace spark plug wires; ACDelco Platinum
 Sea Foam treatment; thru gas tank and plenum
| 3/2009 | 108,500 | Replace idler pulley; ACDelco Replace belt tensioner pulley; ACDelco
| 3/2009 | 109,000 | Coolant system flush; Super Tech 50/50 Right door lock cylinder repaired
 Left door handle repaired
| 4/2009 | 109,250 | Rear brake lines flushed; DOT-3 |
| 4/2009 | 109,500 | Right door lock actuator replacement; Ford OE Automatic transmission fluid change; Valvoline MaxATF
 Rear differential fluid change; 80W-90
 Power Steering system flush; Prestone P/S fluid
| 4/2009 | 109,750 | Fog lamp installation Keyless entry remote programming
 New A/C low cycling switch (Santech)
 New Visteon A/C compressor
 Flush A/C lines/condenser/evaporator
 Replace A/C muffler line (used OEM)
| 5/2009 | 110,250 | Replace RF brake rotor/pads, NAPA |
| 5/2009 | 110,500 | Rotate tires |
| 5/2009 | 111,000 | Replace LF wheel bearing (Timken) |
| 6/2009 | 111,500 | Replace Front sway bar endlinks (Motorcraft) |
| 7/2009 | 112,000 | RF rotor turned (warped) PI Intake manifold swap
 J-mod (mild; 1-2 springs in, 2-3 out)
 New trans. filter; Motorcraft, 1-2 & 2-3 accumulator pistons upgraded; Motorcraft
| 7/2009 | 112,500 | EEC tuning for 93 octane fuel; Lonnie Doll 80mm ‘02 Mustang GT MAF sensor upgrade
 Replace LF UCA; Motorcraft
 Replace fuel filter; AutoZone
| 8/2009 | 112,750 | Replace RF rotor; NAPA/Raybestos Tires balanced, rotated
 Replace alternator (from ’02 4.6 Explorer w/ 60,000 miles); new volt. regulator, 10% larger pulley
| 8/2009 | 113,000 | Auxiliary transmission cooler install; B&M 70264 (post stock cooler; inline) |
| 8/2009 | 113,500 | Oil change; Valvoline MaxLife synthetic 5W30; Motorcraft 820S filter |
| 10/2009 | 115,000 | Tire rotation PI cam swap
| 10/2009 | 115,250 | Replace original alternator, new volt. Regulator, new bearings, stock pulley |
| 10/2009 | 115,250 | LF rotor, brake pads replaced, NAPA |
| 10/2009 | 115,500 | HID projector headlight retrofit, 6000k |
| 11/2009 | 115,750 | Front O2 sensors replaced (Denso) |
| 1/2010 | 118,000 | New water pump, Spectra Premium |
| 2/2010 | 118,750 | PBR dual piston front caliper upgrade/line flush, Raybestos Advanced Technology ceramic pads, Raybestos Advanced Technology rotors |
| 3/2010 | 120,000 | Tire rotation Kenwood KDC-MP345U Head Unit install
 4x Boston Acoustics S-85 Speakers install
 JVC KS-AX3002 amplifier install, bridged to sub
 Panasonic SB-W740 subwoofer install
 Replace A/C compressor clutch/pulley; NAPA
| 4/2010 | 120,500 | Replace Radiator; Silla Oil change; Valvoline SynPower synthetic 10W30; Motorcraft 820S filter
| 4/2010 | 120,750 | Dante replica Cobra R 17x9” rims, Firestone Firehawk Wide Oval 255/45 (summer tires) installed McGard locking lugs, code ------------------------
 Power steering pump replaced, Motorcraft
 Rear brake lines replaced (splice at ½ point near frame rail/double flare fittings)
| 5/2010 | 122,000 | Add oil; ½ Qt. Valvoline SynPower 10W30 |
| 10/2010 | 124,500 | Replace drive shaft (’93 Mark VIII one-piece aluminum) Replace right halfshaft seal (Timken)
 POR-15 underbody paint application
 2-1/2” mandrel bent dual exhaust install, Dynomax Super Turbo mufflers, Thunderbolt spun cats (Mandrel Exhaust Systems (TruBendz Technology))
| 12/2010 | 125,250 | Drive shaft balanced (Henderson Drive Line/Axle) 3.73 traction-lok gears installed (New halfshaft seals – Timken, resealed rear cover, FRPP gears, Valvoline SynPower 75w-90 synthetic gear oil)
 21-tooth speedometer gear installed
| 1/2011 | 125,250 | Repair power antenna Install muffler tips, general exhaust install touch-up
 Replace EVAP system vacuum lines; purge flow sensor (BWD CP509)
| 2/2011 | 125,250 | Oil Change (Valvoline SynPower 10W-30, Motorcraft FL-820S) |
| 2/2011 | 125,250 | Repair A/C recirculated/fresh air blend door |
| 3/2011 | 125,250 | Replace battery (850 CCA Autocraft Gold) |
| 3/2011 | 125,500 | Replace wiper arms (Michelin Stealth) Replace battery tray (Used OEM)
 Scangauge Plus installation
| 4/2011 | 125,500 | Replace lower control arms (TRW) Replace strut rod bushings/control arm side (Motorcraft)
 Replace RF ABS sensor
 Repair HVAC inlet seal
 Wheel alignment (Firestone)
| 7/2011 | 127,500 | Kenwood KDC-X595 head unit install |
| 9/2011 | 128,250 | Replace Multi-Function Switch (Motorcraft) |
| 9/2011 | 128,750 | Torque Converter Install (02 Mustang GT 11.25” OE; pink dot) |
| 11/11/2011-3/6/2012 | 130,000 | Body/rust repair, fresh paint (PPG 2 stage E9 Laser Red); Ed’s Auto Reconditioning Replacement LH door handle (Ford OE)
 Replacement RH door (1996 T-bird)
 Replacement RH fender (Mill Supply)
 Replace rusted/damaged sections of R/L rocker panels (Mill Supply)
 Replace Door lock, ignition lock cylinders (Ford OE, key code -----------)
 Upgrade fuel pump (Walbro 190 lph)
| 3/2012 | 130,000 | Stereo Amplifier install (Sound Ordnance M-4075) Fold down rear seat back install (90 XR7)
 Modified instrument cluster install (stock w/ 97 Taurus SHO speedometer & Tach; SHO faces, rewired/repinned)
 Replace Serpentine Belt (Goodyear Gatorback)
| 3/2012 | 130,250 | Underdrive Pulley installation (Steeda) Replace Water Pump (Motorcraft closed vane design)
 Oil change (Valvoline SynPower 5W-30, Purolator filter)
 Coolant System Flush (Prestone flush)
 New Coolant (Peak/Super Tech 50/50)
| 4/2012 | 130,250 | Grind away/paint over floor pan, seat tracks rust (RustOleum hammered finish black) Shampoo interior carpet/upholstery
 New wheel lock nut
| 4/2012 | 130,500 | Air filter cleaned/re-oiled |
| 4/2012 | 131,000 | Torque Converter Install (DirtyDog Performance 10” 3500 stall) Transmission Install (
 DirtyDog Performance rebuilt 2004 Mustang GT 4R70W; 72.5k original miles, new fluidstock ’97 repainted black with severely J-modded valve body)Replace Transmission Cooler lines (3/8” Aluminum)
 New transmission cooler (tiny, no idea what it is)
| 4/2012 | 131,000 | Install illuminated cruise switches (95 Mark VIII clock spring, 04 Mach 1 steering wheel, 95 Mark VIII cruise switch faces/electrical, 96 Mustang horn switch/harness, stock air bag) 24#/hr. fuel injectors installed (Bosch type III)
 Don LaSota Tune programmed
| 5/2012 | 131,250 | EGR tube replaced |
| 6/2012 | 132,750 | Crank sensor replaced (Motorcraft) |
| 11/2012-3/2013 | 136,000 | Replace heater hoses (Dayco) Replace radiator hoses (Dayco)
 Replace motor mounts (DEA)
 Replace oil filter adapter gasket (Fel-pro)
 Install PI heads (Stage 2 ported, Stage 3 +1mm valves, Nick McKinney @ Modular Head Shop)
 Install Stage 2P Cams (Bullet Cams)
 Replace front timing tensioners, guides, chains (Ford)
 Replace coolant
 Change oil (Valvoline SynPower 5W-20, FL820s filter)
 Replace oil drain plug (Motorcraft)
 Replace oil dipstick tube (Lokar)
 Replace valve cover gaskets (unknown)
 Replace shifter trim/indicator
 Replace IAC valve (Motorcraft)
 Replace spark plugs (Motorcraft 22C)
 Replace spark plug wires (Motorcraft 8mm)
 Install driver side head coolant mod
 Replace TPS (Motorcraft)
 Replace EGR vacuum solenoid (SMP)
 Replace fuel pressure regulator (SMP)
 Install 30#/hr fuel injectors (Bosch type 3)
 Install FR500 steering wheel
 Install new rear tires (Nitto NT555 255/50/17)
 Install new speedometer gear (Ford 20 tooth)
 Install illuminated headlight switch/trim (98 Mark VIII OEM donor, Radio Shack relays)
 Replace RH muffler hanger clamp
 Install stainless steel exhaust tips
 Replace EGR valve
| 5/2013 | 137,250 | Change oil (Valvoline SynPower 5W-30, FL820S) New transmission fluid cooler (B&M 70274)
 Replace ½ transmission fluid (Valvoline MaxATF)
| 7/2013 | 139,000 | New subwoofer installed (JL 8W1V2-4 in factory 92-94 JBL enclosure; 14AWG speaker wire) |
| 7/2013 | 139,500 | Change oil (Valvoline SynPower 5W-20, FL820S) Install ported FRPP 70mm Throttle Body (618jerrys)
 Install ported SN95 plenum (618jerrys)
 Clean instrument cluster contact terminals
| 10/2013 | 141,500 | Replace Passenger headlight ballast (autoretrifit/ebay) Replace headlight bulbs (4300k, autoretrofit/ebay)
 Add oil (1 qt SynPower 10W-30)
| 3/2014 | 143,250 | Replace battery (AutoCraft Gold – warranty exchange) |
| 3/9/2015 | 148,250 | Change oil (Valvoline 5W-20 synthetic, FL820s) |
| 8/2015 | 149,500 | Replace hood Replace F bumper cover
 Replace header panel
 Replace F headlights/reinstall projectors (OEM)
 Bleed brakes
 Install seat upholstery (SCP Deluxe leather)
| 9/23/2015 | 151,350 | Replace spark plugs (Autolite APP103) |
| 12/12/2015 | 152,850 | Replace inner tie rods (Mevotech Supreme) Replace outer tie rods (TRW)
| 1-3/2016 | 152,850 | Rebuild differential (Henderson Driveline – extra clutches, 80W90 Limited Slip Valvoline Conventional) New front differential bushings (Energy Suspension)
 New rear knuckle bushings (Energy Suspension)
 Install braided SS brake hose (RR)
| 4/12-14/16 | 152,850 | Wheel alignment Install R sway bar links (Moog)
| 4/18/16 | 153,000 | Replace ambient air temp. sensor (SMP) |
| 2/18/17 | 155,750 | Replace valve cover gaskets and grommets (Fel-Pro) |
| 2/24/17 | 155,750 | Change oil (Valvoline SynPower 5W20 HM, FL820s) |
| 3/2017 | 155,750 | Front brakes replace/upgrade (13” SN95 style, Raybestos Advanced Technology calipers/rotors and reman. Cardone calipers) Remaining SS brake hoses installed
| 7/16/17 | 156,900 | Switch upstream O2 sensor sides |
| 7/20/17 | 157,050 | Inject grease into both lower ball joint boots |
| 2/20/18 | 157,231 | Replace front lower control arms (TRW/Moog) Bleed master cylinder and brake lines
| 1-3/22/2018 | 157,231 | Replace transmission (BC Automotive 4R70W: 2007 and 2004 hybrid– 7P direct, 6P forward, with drain plug) Replace torque converter (Circle D 245mm 3C)
 Flush transmission cooler
 Replace 4 O2 sensors (NTK)
 Replace rear transmission mount (DEA)
| 5/26/18 | 158,200 | Replace RF rotor (Raybestos AT) Reprogram PCM for 87 octane
| 6/13/18 | 158,250 | Replace R UCA (Moog) Replace RF wheel bearing (Timken)
| 9/27/18 | 159,500 | Replace radiator (Fluidyne Custom Aluminum) |
| 3/18/19 | 159,800 | Wheel alignment (Van’s auto service) Tires balanced (Van’s auto service)
| 3/26/19 | 160,150 | Change oil (Valvoline MaxLife 5W30 blend, FL820s) Replace transmission dipstick O-ring
| 7/26/19 | 161,500 | Replace rear tires (Nitto NT555 G2 255/50/17) |
| 11/19-7/21/20 | 162,400 | Replace rocker panels and treat corrosion (Chill’s Body Shop) Replace battery (Die Hard Gold)
| 8/18/20 | 163,380 | Repair LR tire puncture |
| 3/22/21 | 165,000 | Change oil (Valvoline SynPower FS HM 5W30, FL820s) |
| 6/12/21 | 166,250 | Replace LH window regulator gear plugs (Dorman) |
| 8/23/21 | 167,000 | Replace F tires (Nitto NT555G2 255/45/17 – Sylvester) |
| 10/20/21 | 168,000 | Replace LH window regulator gear plugs (Dorman) Repair instrument cluster bezel
| 11/20/21 | 168,300 | Install long tube headers (Dave Dalke; SN95 MACs modified by “General Zod”) Modify headers for EGR (Dave Dalke)
 Replace oil pan (OEM donor)
 Change oil (5W30)
| 12/5/21 | 168,500 | Replace hood struts (“A-Premium” – Amazon) |
| 3/2022 | 168,750 | Replace valve cover gaskets (Victor Reinz) Replace intake manifold gaskets (Fel-pro)
 Re-plumb heater hoses (Gates)
 Change coolant
| 4/26/22 | 168,860 | Replace spark plug wires (Motorcraft) |
| 8/3/22 | 169,824 | Replace brake light switch (Standard Motor) |
| 1/13/23 | 171,400 | Kenwood KDC-X998 head unit install |
| 11/5/23 | 175,400 | Change oil (Valvoline SynPower HM 5W30, FL820s) |
