- North Ridgeville, OH
The PCM is set up for roughly the following behavior:
3-4 shift occurs at about 35 MPH (exact speed varies per calibration; if your speedo says something way off, it's probably just an inaccurate needle placement)
TC locks over about 2 seconds, assuming TC slip as the TCC applies does not exceed a certain threshold (in which case the shift will complete and the TC will remain unlocked until the slip drops below the threshold)
A 4-3 shift occurs at about 32 MPH.
The TC will unlock in 4th gear before the 4-3 shift, usually at around 33.5 MPH (again, varies with calibration). The TC will lock again when speed exceeds 36ish MPH.
With a cold TOT (usually under about 50F, again this varies) the converter will stay unlocked. The 3-4 shift point is also lower - about 32 MPH.
The upshift speed is always a few miles above the downshift speed.
