The DIY Home Improvement Thread
CDsDontBurn
USA
97 Thunderbird Sport
I'm starting this thread more as a general small project help section, a "look what I did", or a "I need ideas for X project". Many of us here seem to have something going on and it's be cool to see it.
I'll go first. My front bathroom needs a mirror hung up and my wife wants it to be "frameless", meaning, no hardware attached to the mirror.
I've looked around and from what I can see, LocTite PL-530 is the best stuff to get, but I can't find the stuff anywhere in stores. What else can I get in lieu of that? I picked up some Gorilla Glue as it says it's for everything, including mirrors, but I'm not as confident in it as it seems more general use adhesive vs specific to hanging mirrors.
The other part of this I'm finding difficulty on is surface prep. I'm finding that it's about 50/50 say it's ok to hang straight to painted surfaces whereas the other half say to remove the paint first of the surface has already been painted on.
I'm ready to make this happen, but I need clarification on what to do here.
Glue scares me, because I could see it pulling the mirror backing off. Mine has the ugly see thru tabs as I'm too cheap to try anything better
Personally I wouldn't leave the task of holding a mirror ons wall in a bathroom to just glue.
I use construction glue but in addition to the hidden stainless hardware that mounts on the studs and has small clasps to grab the mirror.
Like these.
If the mirror isn't coming off, does that matter?
And yes, I was going to do the cheap hangar things you reference, but the wife wants a clean sleek look, and there's nothing more slick than no hardware.
Like these.
Is only a small sliver of these actually seen? The front of the hook, I presume?
Depends on the weight of the glass, gorilla glue double sided tape is pretty strong and might be what you’re looking for. There even Velcro that might get the job done assuming the glass your using isn’t too big.
So instead of buying a couch I decided to make one, pretty easy 4x4 bases, 2x4 sitting frame. Gonna have to hit the Home Depot for some more wood for the middle section. Next thing would be making the cushion’s. Pretty much an outdoor couch type. Since I like a deep couch, this was the best way for me to get my DIY fix 😬. I’d like to add some USB port’s and maybe a cup holder on the sides.
I'm starting to wonder if I even enjoy couches... I don't recall. Maybe a reclining couch will change my mind. Or just havent sat in a good one in a long while
Look for another product called Mirror Mastic. I guess the brand must not have been trademarked because there appears to be a few manufacturers for it, Seal Bond, CRL, and Gunther, and another similar product by Palmer called Mirro-Mastic.
Thanks, I'll look into that. I take it it's okay HD or maybe Lowe's?
And surface prep? Just straight onto the wall, painted and everything? Or do I need to peel off the existing paint and expose the drywall?
I was searching on the web. This is the Seal Bond version on Amazon.
Lowe's appears to sell the Loctite PL Max, which judging by its name should be better than what you found at HD.
I don't have experience with these products, but I would use them if I was getting frameless flat mirrors for my bathroom renovations. I'm confident that these products are what builders use since the frameless mirror has been a staple of new bathroom construction for the last 20+ years and I never see them with mounting clips at the edges anymore.
As for whether it's safe to apply on painted walls, I guess that would depend on the paint that's already there. Was the wall primed properly before painting? Has it been painted over more than once? Does the paint on there now come off in chips or flakes? Is the wall textured like every residential wall I've ever seen in SoCal? I would not try to peel off the existing paint because if you damage the paper facing of the drywall, it's basically useless as far as using it as a mounting surface.
I think the safe thing to do would be to replace the section of drywall behind the mirror and don't paint the part that will be hidden after the mirror goes on it. Given a certain set of conditions, I'd even consider going a step further to replace the drywall with cement board, but that can add even more complexity if you aren't replacing the entire wall and this was supposed to be about putting up a bathroom mirror.
Wall condition is:
  • New green board (moisture resistant drywall, as I'm sure you know)
  • Primed before painting
  • Two coats of paint when originally painted (three coats if counting the primer)
  • Coming up on 3yrs old this fall
Like I said, I'd be down for the little plastic clips and call it a day, but my other half wants a sleek look.
Can you adhere something to the back of the mirror and hang the mirror on the wall on those? Gluing something to drywall doesn't sound that appealing to me if/when tastes change, much like how I will never install ceramic tile in any house I live in ever again.
I have the opposite going on. I need to figure out how the hell to remove a mirror glued onto a wall.
I put this vanity in a few years ago to replace the early 2000s builder grade stuff.... left the mirror alone. Now the mirror is starting to delaminate at the bottom.
Not sure how to get it off the wall without making a mess.
Goal is to get rid of it, fix the wall, and then get a big hanging mirror and new vanity light.
Also, I helped my uncle back in the 2000s with remodeling a bathroom. We hung a large mirror with those hidden clips. We ended up shattering two mirrors, the third one we finally got hung. So be careful, one tweak the wrong way and they are done.
If I were to do it again, I would probably just do glue and not risk using the clips.
Wall condition is:
Take this for what it's worth, but it seems like a properly painted wall shouldn't be a problem for Mirror Mastic, or if nothing else, you can scuff the areas where the adhesive will go on the wall.
The third post in the thread is a separate concern, one which I don't know how to answer and can't say whether it's a universal issue after 15 years. Whatever my builder used in my bathrooms has held for 17 years and counting with no seep-through staining.
I'd just lightly sand the area you put the glue. That way it's not getting to bond with a gloss surface.
I'm debating with my wife on redoing my fence with my neighbor as a DIY project or paying someone to do it for me.
Or maybe have it be a halfway DIY project. The hardest part for me would be to ensure that the posts are all lined up properly. The "halfway" part would be to hire someone to do the posts and get everything lined up for me and then I just go and finish up the paneling myself.
What I really want is for a cinder block pony wall topped by vinyl fencing.
Put a post at each end get contractor string stretched tight and use a level on the post so it touches the string and is vertical, plump.
Have you thought about the lawn? :unsure:
Are there Lowes or home depot stores there?
Like Fred said, contractor's string, a plumb bob, and something that will dig post holes. Concrete, posts, and prefab fence sections. If they allow irrigation systems, I'd consider it. The last fence we put around the pool is plastic, rated for 25 years.
The original wood fencelasted about that, but required painting every few years.
You could just replace the bad boards, and paint it.
Had a pinhole in a copper line in the wall this week. Second one in a year. I am going to re-plumb whole house thru attic w/ pex. Anyone have experience w/ pex a or pex b? I'm leaning toward b but experience I am short of. Any advice from lessons learned are appreciated.
I'm not confident in that type of skillset without having been shown how to do it first.
It's actually on my list! But it's not going to be DIY. Got a quote for $1,300 for my front yard and $1,800 for my back yard. It will be the last thing I get done, but it won't be DIY. I'll post pictures elsewhere when that's done.
That's most yards in So Cal. Not enough moisture to grow much lawn.
That's why we have sprinkler systems! Plenty of green lawns out here in SoCal because of sprinkler systems. It's also the largest contributor to our water problems, lol.
Pex A is better. Youll need the expansion tool for the fittings.
I've done plenty of poly ethylene ( pex ), poly propylene ( socket fusion welded ) and next week I need to get a cert for HDPE fusion weld to install natural gas line underground at Cal Trans facility. Copper and weld steel are my forte though.
Since you were talking about pipes you all might find this interesting. A few years ago I was replacing my laundry room sink. I had to pull the baseboard trim to finish it properly. Everything was going great..... until I removed the last nail from the trim. After pulling it out water started spraying out of the wall. :2eek:
Apparently when the house was built, and the trim was being installed, a worker shot a nail right into the CPVC water pipe.
Somehow it never leaked, until I pulled it out. You can even see the mineral buildup on the nail where it went through the pipe.
I guess the nail was hot and going fast enough to form a seal.
I’ve used PEX with shark bites, really easy to put together and can go on copper also. The shark bites are expensive though.
I called every plumber in town trying to get a dishwasher installed; no one knows how to sweat copper anymore, just pex or pvc.
I've finally recovered enough to give it a shot. I'm going to have to buy a stick of copper and pvc, and a vampire tap for the drainline.
Years ago, we put in a full size mirror medicine chest, all glass, mirror outside, mirror inside, clear glass shelves, no frame. It comes with mirrors on the sides if you mount outside of the wall. We like it. I will see if I can find the make and model.
I can sweat copper if I have to. Last year thr flex copper on the water heater developed a pinhole and I was like well it was a fluke. My ktr friend at church said get ready as he's replumbed 15 in town. I'm on a slab so no access short of a demo saw and I'm not interested in doing my hardwood floors a 4th time. Sometimes I wish I wasn't a diy everything as it sucks time and my list keeps growing . I'm on the 5 yr maybe 7 retirement target so I can get some of my stuff finished.
