Is there any information on the side of the breaker? I've never seen one like that.
There is. You can make out that there's writing on the side of the breaker there, but it's covered in dirt and dust.
Well shoot. If it's covered in dirt and dust we'll never know what it says.![]()
That is an old push pushmatic panel, known for issues. You can find replacement breakers but I'd advise on getting that panel replaced. Not as bad as the old Federal pacific panels but pretty close. As an electrician I cringe every time I see one of those still being used...that being said, I've you need any advice/help replacing it feel free to message me. Also, I noticed that breaker is double tapped, meaning there are two wires on the breaker. That's a big no no on those. Looks like you have extra space in the panel so if you plan on keeping it for a while you might want to grab two breakers.
There is a main breaker, for the whole box. This is what makes it a 60A box, or 200A box.
TURN OFF THAT BREAKER.
Just tell her your installer doesn't do herring bone. Worked for me when we did our paver brick patio.Continued my slow rolling flooring project today. Moved the couch out of the way, cut up a chunk of carpet, removed the 9" brown tiles that are original to the house, and used the stripper stuff to remove the black mastic.
Sofa back in its spot. This big section of carpet is next. House smells of the stripper stuff. I'll be working on this some more tomorrow since it'll still be raining here in SoCal.
All I know, is that it'll be nice once we have actual flooring installed. We got these long planks picked out that we'll be installing, and my wife wants them in herring bone style. That'll be...... fun.
I just installed a similar Giraffe hose reel in back by our pool. Had to make the post and mount it into the concrete deck. Made a little access panel so I could route water through the lanai. Took me longer than I thought but most of my projects do.
Does anyone have experience with bishops weed or gout weed? I've spent a good amount of time trying to pull them but its starting to take my lawn. I want to avoid chemicals for quite a few reasons, but one of them is worry about harm to other plants. A torch might be a good start but I dont want to adopt a propane tank just to use a small amount
