Grog6
Moderator
- Harriman, TN
For a lower viscosity fluid, the orifice size would change on all of the solenoids, the EPC valve would change,valvebody, everything. It's literally a new case. Those trans do not swap with ours, IDK what plate changes there were, but they would not work for us. Our 4r70 needs a plate that releases cleanly with no chattering, and then has fast lockup when the clutch closes. The apparently, direct is also held closed with pressure; that going away from the scarf cut seals smokes a transmission before you can move your foot.
