Grog6
Moderator
- Harriman, TN
That drain gets clogged by insects a lot. Here, anyway.
In the pan .. temps are higher and lower at the radiator / cooler .. the pan temp represents what filter pulls in.
1997ThunderbirdLXV6, is that torque you’re using to log temps?
I’ve not been able to get trans temp, did you have to do anything special?
Sounds like I need to J-Mod my '96 then....Our transmissions survive longer by faster shifting, the stock shift schedule and un j-modded plate heats the fuck out of the trans.
In a later trans, you can see the thermistor mounted to the circuitboard. IDK where it is on the older ones
I played with torque today, I have the paid version. I found out how to add manufacturer specific PIDs and probably got a dozen more data points including trans temp. A cooler moved up on my priority list. I know trans work is inevitable at this point, but I’d like to make this one last as long as I can.Torque does not have an option for trans temp, your info above may help me set it up. Thanks.
Has anyone done a sub box in the spare tire well in one of these cars? I wanted to do an enclosure in the driver side behind the rear wheel, and battery on the opposite side. Didn't think I could get golf clubs in the car if I do. Thinking sub near the back and battery up front of the well if I can get enough sq ft for a box.
Trying to get weight as far back as possible, but still look professional-ish. Thoughts?
Thats what I was thinking. It's close to big enough, but maybe not. I'd build a full box to fit in the well.It's awfully small for a box, and the metal adds overtones. You want a box to be acoustically dead, like particleboard or glued sonotube. My current jbl subs only beed 1.5 cu ft, so they
re a possibility.
Depends on the kind of washing machine you have. If it has an impeller, just put your seat covers in a big pillowcase or something to keep it together. I would suggest you avoid trying if your machine has an agitator.
Let it air dry.
I have a stupid question which might be more of an opinion than definitive rule. I have a '95 Thunderbird and after reading the advice of quite a few people here I have abandoned any thought of rebuilding my original engine and will instead find a '99-'00 4.6 out of a Grand Marquis.
So, since I want to make this car as much a throwback to the old muscle cars vibe as is feasible, I want to paint the motor the same way that an old Ford performance motor would have been painted in '69-'70. That means whatever official Ford blue engine paint, but which parts should be painted blue and which parts should be left alone? Valve covers, heads, intake, block, timing chains cover, water pump? Back then did it matter if the motor was a big block or a small block?
On all my old Ford motors I use Duplicolor DE 1606 Ford Dark Blue. Bout as close as your gonna get. That's the factory shade of the 69 mustang 250 I've got in my 77 Maverick and the 69 mustang 302 I have in my 55 Ford Fairlane...It depended on the spec of the engine, a 69 302 2V with cast iron intake and stamped steel valve covers would be 100% blue, while a Boss 302 with the aluminum intake and either chrome or aluminum valve covers would leave those bare/shiny. Same goes for a 428cj in a Torino Cobra vs a standard 428 in a country squire station wagon.
Ford(and all manufacturers) painted the entire assembled long block including intake manifold water pump, harmonic balancer bolt heads and sometimes even exhaust manifolds etc in the corporate color. Accessories like pulleys, the carb, air cleaner(though the housing/lid was most often blue too on Fords) chromed or cast valve covers and aluminum intakes would be added after the long block was sprayed.
Make sure you get the color correct too, there are several shades of Ford blue and 69-70 would be the darkest one
I like the throwback paint idea, keep us up to date with pictures.
My stupid question: why the Grand Marquis engine?
