Little Ice-Cable
Does the 1996 Thunderbird have a cigarette lighter in it.
Ok thanks, I am a new thunderbird owner so I have been looking for it and could not find it.Yes, under the (drumroll) ash tray door![]()
I got this one at the junkyard to customize so I could have a cigarette lighter but it is the same one that is in my car
I have looked everywhere for it, so I assume they did not.It’s possible they relocated it to keep it as an accessory socket but you’ll have to look around to find it if it is there
I am also have been looking for those at junkyards, but I think I am just going to modify my extra consoleThat is the 1997 style center. 1997 got an ashtray that goes into the lower cubby below the radio and HVAC controls.
I have 1997 ashtray that I have no use for. Lemme know if you want it or can't find one locally at the JY, I'm happy to send your way for the cost of shipping.
I installed the lighter in the armrest storage since I put my gauges in the lower cubby.
Anyone that's curious. The rocker switch controls the power antenna and the momentary push button controls the light.
*Edit*
I got the light cover/wiring harness from an 89-93 Tbird/Cougar
Thank you, but i think I would rather do the custom console and keep the space on the dash for my phone or anything else.I have 1997 ashtray that I have no use for. Lemme know if you want it or can't find one locally at the JY, I'm happy to send your way for the cost of shipping
Very cool seeing similar but different setups.Nice! I did the same thing with mine. My momentary switch is actually a stock 89-93 one I stealthily put in place of one of the rubber stops
That would drive me crazy knowing the light was always on.My light is just always on with parking lights:
Is the fuel door switch a Cougar thing? ...one of those 'luxury' things that would annoy the hell out of me.
I know the previous owner personally and he only daily drove this car, so I don't think he would swap the whole console.There's a chance, albeit a slim chance, that the previous owner swapped the entire console from a 97, not just the cupholder panel.
There was only one owner before him I believe, and she was an old lady, so I don't think she would have done it either.Depending on how long he owned it for it may have been swapped in even before him, that’s been a popular mod to 94-96s since the early 2000s at least. If it’s got the correct air tube the console would basically have to come out to put it in anyway.
I have not removed it yet, currently it is in the body shop, getting a lot of stuff done to it (rust removal, fixing the bumper, headlights, and getting the whole car repainted.) when it gets back in a week or so I am going to start doing the other modifications like the console.@Little Ice-Cable
Have you already taken out the cupholder that's in there now, that your car had when you bought it?
If so, what was the condition of the air duct. If it has a piece cut out [most likely] to make room for the cupholder, then it's the original duct. Then it's certainly also the original console, and the wiring for the lighter is part of the console harness.
If the air duct is intact, then one of two things happened:
- Either the console was disassembled to swap only the air duct [somewhat likely] --> lighter wiring still there
- Or an entire 97 console was put in [least likely] --> no lighter wiring in the console, but the lighter lead is on the dash side of the console connector below the coinholder (on the console side of that connector, that pin is empty.)
If you haven't taken out the cupholder yet, start there and let us know what you find.
It needs the whole repaint pretty bad, there are scratches and marks all over the car and since my dad runs the body shop, I'm getting a pretty good deal on itFull repaint? Wow, I'm jealous. Nice stuff!
The wire for the lighter is light blue/white. The connector is C253.
These diagrams are for a 97, so it says "not used", and the male side of the connector shows as empty; but on your car this is used (or at least was). Meanwhile I imagine that splice S202 you see there doesn't exist on pre-97.
Interestingly, this is not the same wire as power to the trunk button, probably because it's fused to a higher amperage (?).
since my dad runs the body shop, I'm getting a pretty good deal on it.
It was him he hops on here sometimes and buys stuff for my car. He has owned multiple thunderbirds, so he knows (at least he thinks he knows) what I want and need for my car. It's going to be the same color.Sweet!
I think your dad bought a shift knob for it from me, because the existing shift knob suffered from leaking goo syndrome. Or maybe that was someone else's dad...
Anyway, keep us posted. Definitely show us the repaint when it's done. Same color?
I do really enjoy the shift knob though, it is really nice compared to the goo syndrome one.Sweet!
I was reading a post by someone else (I cant recall who exactly) and I found out according to that thread that its possible to bolt up the rear section of the 4.6 t-bird exhaust right to the rear section of the 3.8 exhaust. Is this true? I know it would be only cosmetic and net no real performance benefit at all, but I like the look of dual rear exhaust. Also, if I were to grab the rear section from a junkyard, what tools exactly would I need to get it off? like what socket sizes etc.? (i know rust could cause problems)
Removing those brackets above the mufflers creates a whole new world of issues for you, because when you fuck them up, which you will, you will find that these hangers are actually the rear bumper hangers.This is true, it’s just a ball and socket flange after the resonator with two bolts that will probably put up a good fight. The stock pipes are actually low grade stainless steel so they look rusty on the outside but it’s only cosmetic, but the hardware is just plain steel so they’ll probably be seized and the heads swollen with flakey rust, probably wise to just take a saw and cut them to get the pipes detached and just get new nuts and bolts from the hardware store.
The hardest part of dropping the rear section of exhaust is frankly the rubber hangers, especially the one by the diff as the other two above the mufflers you might get lucky and be able to unbolt the brackets (those need a 13mm deep socket). Bring a long screwdriver and spray lube with the straw thingy for the nozzle and get it up in the rubber the exhaust is hanging from, and use the screwdriver to pry the rubber off from the hanger
