New stupid question, is the Volts gauge supposed to have the needle in the middle, or just to the right of the middle of the range, when idling? I've noticed lately that my car idles low, like 600rpm at a stoplight and the Volts gauge needle is just to the left of NORM. As soon as I hit the gas the needle is back to centered or just right of center. I ask because my battery is losing charge (it is old, it probably could need replacing) to the point that a couple times I've had to boost it to start the car.
A related question, what rpm should this car ('95 4.6 V8) be idling at? Sometimes, when cold, it idles at around 750rpm and the Volts gauge shows the needle at the normal(?) position of just right of center. But after some minutes of driving it's back down to around 600rpm at idle and the Volts needle is just left of NORM. With the lights on everything dims (lights, dash lights) at idle until I give just the slightest bit of gas, then it's back up to normal again. This is with and without A/C on. If I put it in park it idles at 750rpm and the charging is normal.
So, it's that expected? Is there something wrong with my alternator or maybe what the computer thinks it should be idling at? Would a weak battery cause the charging system to react differently compared to a new, fully-charged battery?
