It looks like the sleeves for the Continental bushings are solid instead of the split sleeves that typically come with the bushings for our cars? I wish they would have just used a lower A-arm instead of these stupid strut rods.
I need F3LY-8A080-A (the coolant overflow tank) for a 97 V8 Tbird. Anyone know how many years I can go back and still have them fit, and if they're the same in both V6 and V8 cars?
Cool, thanks. There's a 94 in a junkyard near me, so I'll head over and see if it's a V6 or V8. Any tips on pulling those tanks?
In plenty of coolant change tutorials, I hear that you should turn the heater to WARM in order to circulate the new coolant.
Am I right in assuming that A. they say that because some cars have a valve that only directs coolant through the heater core when the heater is turned to WARM, and B. that our cars don't have such a value, and coolant goes through the heater core no matter what?
Is there any other reason to do this?
Thanks. This sounds like a good approach, although it seems that those refrigerant cans are not for consumer sale here. I could probably import some from outside EU though..The cycling like that is usually due to low refrigerant. Before you go spending a bunch of money at a shop, get one of the cans with the gauge on it and try adding refrigerant to it. If that causes it to stop cycling, and there is no noise and the system starts getting cold, then at least you know the system works, and you can bring it to a shop to have them find and fix the leak, and recharge it properly.
Not really, autozone seems to even geoblock european connections. Rockauto works fine, I've placed a few orders from them, the delivery takes about a week.Autozone, advance auto, do any of those exist in europe?
It is useful for about 2-3 months per year. It is true that a functional heater core is more essential for the rest of the year'Totally understand the goal of a full functioning bird but AC in Finland is an interesting concept
or am I missing something?
If it’s a rear wheel, it could be an axle seal.This question is about my 2000 Explorer, but probably pertains to any vehicle. I walked by it today and saw what appears to be oil dripping down the rim and tire; feels oily to the touch. There is some on both the face and inside of the rim. Only on the bottom half, but not coming from the axle / wheel bearing. I pulled the wheel and the top brake piston has road debris whereas the bottom piston was relatively clean. I could not see any leak path. All fluids are at an acceptable level. Brake pedal feels normal both running and off. After cleaning and working the brakes there was no evidence of leakage. I did not remove the caliper. Hoses have been replaced and still look new.
The only thing that makes sense to leak on the rim like that is brake fluid, or am I missing something?
Amazon.com: Standard Motor Products TX12 Temp Sender/Sensor : Automotive
Buy Standard Motor Products TX12 Temp Sender/Sensor: Coolant Temperature - Amazon.com ✓ FREE DELIVERY possible on eligible purchaseswww.amazon.com
