Here's a definite stupid question. Are these:
Prothane 61709 Rear Lower Spring Isolators - IRS | Energy Suspension Parts
Rear Coil Spring Isolator Pads made by Prothane | 61709 Rear Lower Spring Isolators - IRS.www.energysuspensionparts.com
the same as:
Rear Spring Cups - Poly Upper and Lower
<p>Are you unhappy with the ride height of the rear of your car? Do you have a large stereo and the car sits low in the rear? Well, this common problem is now easily solved with our poly upper/lower rear spring cups.</p>www.supercoupeperformance.com
Not necessarily 100% the same part, but designed to serve the same function?
This.I've been known to put the jack under the spring perch of the LCA.
So 1 or 2? 1 looks like it could bend under load (?).
And then stands here?
Also if they already drained all the fluids out,
If the wheels are off, it will take less effort to turn, so that may be part of it. .
. It is also possible that the resistance in the ball joints is higher in your car than the ones in the junkyard.
. Honestly I wouldn’t think too much into it.
stupid question: do we check trans fluid levels on dip stick with engine running or off?
Speaking of worn lower ball joints, what are signs of worn lower ball joints?
