CDsDontBurn
		Good to know. I see RockAuto has them for $6/ea.
		If you need them quicker, you should be able to get them at the Ford dealer too since they were used in many Ford vehicles.Good to know. I see RockAuto has them for $6/ea.
		I use a previous version of these Hikari's. They're great and hold up for years before failing and needing to be replaced.Don't use the retaining ring to push the bulbs in, they will for sure break.
I have these LEDs installed and have been good so far: https://a.co/d/4FuSc2o
		Q: how important are all bolts on motor mounts?
I'm working on replacing the motor mounts on my MIL's Ford Fuckus right now, and the passenger side motor mount has one bolt that will not thread into place (square hole down past my hand). 3 of 4 bolts / nuts are firmly in place though. That said, can I YOLO this bitch or not?
		I’d get a new bolt and possibly run a tap through the chassis threads
That one definitely has to go back. If it was the rear one, then maybe you could get away with it, but the torque from the engine will crack that aluminum bracket without that bolt installed.
		I’m not crazy about LEDs in a halogen housing, but the best I’ve found so far are these.
		If it won't thread into the hole it came out of, loosen the other bolts, yank the bitch around, and try again. Repeat until it lines up.
I have them in my turbo coupe and they’re bright as hell.
		Yeah, 90’s headlights weren’t the best.I did do that before moving on.
I just need better night time visibility. I did a night drive the other day, and it was terrible. I don't want to experience that again.
		Wear leather gloves next time. Lesson learned from experience.Fuck
This car has completely gnarled my left hand today. I hate working on this car.
		Yes.Stupid question:
If I drove 172 miles on a full 18 gallon tank and used 11 gallons of gas, would I be getting 15.6 mpg?
		Stupid question:
		Just to confirm that I asked a stupid question....and you're asking because?
I mean is there anything about this calculation that troubles you? (Worse than expected MPG?)
		That sucks.I did wear gloves! It wasn't leather gloves, but those Milwaukee gloves with the black palm side. These very same gloves, actually.
		The way I drive?! I thought I was getting 11 mgp. So, for short city drives and not much long distance or freeway, that is not bad. I will do another one when I get a chance to go for a long drive.Ohh. I thought you were dissatisfied with 15.6 mpg.
		Same here.....I did wear gloves! It wasn't leather gloves, but those Milwaukee gloves with the black palm side. These very same gloves, actually.
Sure, they're not leather gloves, but it's better than nothing. And I don't usually wear gloves when I'm wrenching, so there's that part too.
That said, I don't wear gloves usually because I can't feel whatever it is that I'm touching when I'm wrenching.
		Same as the one in my Dakota. All the way to the side of the road.The next question is... how long will the transmission last?
