Decided to take some measurements and photographs. Click any image for larger size.
F0SZ-16A550-
A contains two splash guards. I have a set here in the original packaging. They are 13.5 inches (34.3 cm) tall at the peak, and 7.5 inches (19.05 cm) wide at the bottom. They're listed on the packaging as being for both the front and rear.
There's also some others that I've found picture of online. As far as I know, based on a post on TCCOA, both of those pictured below are for 94-97: left for the rear, right for the front. I have no idea what the part code on these two sets are (if you know, please post). I have a second-hand pair of the rights (front) and they fit fine on the rear of my 97.
I also have two sets of E3SZ16A550-B, made for the 9th-generation Bird (as seen on the left). Ford switched to the more modern logo style on the right midway through the 9th gen, in 1985. As you can see, they are the exact same size as the 10th-gen flaps. So, if you like the look of the straight Bird logo, you may want to hunt down these instead.
Below are two bags of 9th-gen flaps, with a loose 10th-gen flap sitting on top of one of the bags on the right to show how they line up (precisely, curve and all).
They were also available in white:
Then we have the SVO Thunderbird flaps.
Bonus round. I also have a set of F0SZ-16A550-
D. The packaging says "pliable rubber", but unlike -A they're more a plastic than a rubber--much firmer. Their packaging says they're specifically for the rears.
But while I was able to get -A to fit on the rears by drilling a few new holes in the rubber, these simply do not fit on my 97 due to the guard lip.
On the left is how they would need to sit if you wanted them to be aligned properly, and on the right is how they actually line up on a 97 Bird rear panel. So it looks like I'll be selling these. EDIT: EricV8Thunderbird reports that they also do not fit on a 94-95 SC.
QUESTIONS:
Does anyone know what year the panel on the back would have changed? Presumably either 94 or 96, but I don't know.
I tried cleaning one of these because it had some rust stains on one side. I used CLR, thinking it would be safe, but it just stripped the paint off instantly. The bird etching is still there, though, so does anyone know a paint I could use to repaint the bird by hand, and that would hold up to the elements?
