- Oct 2, 2023
- New Mexico
As you may know, I have been dealing with a low idle issue ever since I finished my exhaust setup. The car idles at a stop, in gear around 500-550. It will idle at 750 in park / neutral. It used to idle at the average 750 while in gear. It's not the IAC, and I cannot find a visable vacuum leak, but I have a few issues with the tranny and wondered if that might be the issue. Also, its not the MAF or TSP, but if the TSP was adjustable, that could help (but not solve the problem).
Tranny still has a slight clunk when down shifting during when mild acceleration, harder downshift when jumping on the throttle. There is also a slight "lack of smoothness" when changing gears (slight drag sound when shifting). Tranny is a good tranny, but I think the 1-2, 2-3 accumulators are OEM from 94, I think they need to be updated for the issues above. Next oil change I plan to inspect the accumulators and replace with newer model.
Could the gear position sensor, if not exact cause issues like low idle?
Are there vacuum lines that would effect low idle elsewhere than the engine bay? Like going down a fender well to something else I can't see that I am missing? I have checked the canister lines, none of them have a leak.
Maybe back pressure from the new exhaust is causing the low idle?
