LukesCougar
- Dec 27, 2023
- Olney Illinois
- 1997 Thunderbird LX 4.6 Limited edtion - 1996 Cougar Xr7 4.6
So to say the least.. i will be doing most repairs myself and finding a new mechanic
Got under the car to do new struts, to find that the sway bar link on the drivers side was hanging off loosely ( ill assume its been this way since i got the car back.. bolt threads were stripped in the area it would tighten down so they probs ugga duggad it tf on) I found a nut that works, and put washers on until the stripped area was covered up. Took it on a test drive and the front end handles a million times better. I have already ordered a new sway bar link with new nuts, and rear sway bar links cause they need done aswell when i do shocks.
Also when they "fixed" wiring issues they dissconected my od from shifter.. after cleaning contact points, and putting everything back together o/d works for a split second then blows the run 5 amp fuse... Im lost but what i do know is my mechanic was hiding a lot from me instead of digging in to fix the things i wanted fixed.
So when i have time again ima see whats up with the o/d wiring and why its blowing a fuse. When sway bar links get here im going to finish front suspension ( by me and myself and i and not some lazy mechanic)
Im not very experienced so it blows my mind that an ASE certified mechanic and his boys screw me over and my car. Should i request they do me right? Legally can i do anything about this or should i just leave it be and find a better mechanic?
Edit: forgot to add context to suspension issue but i gave my mechanic a whole 10pc kit to refresh the front end and it appears he didnt install half the parts i gave incorrectly and one part he stripped the threads
