Well snot. Found the coolant leak.
Generalee0527
SW GA
97 Tbird, pbr front brakes, Sport edition 4.6 w/ 369k total miles by me the one and only owner.
Been pulling my hair out trying to pinpoint where emy coolant is going. Started w/ new heater core, more hose clamps, intake gaskets, thermostat housing o-ring. Can't even make a 5 mile round trip w/o having low coolant light come on. Been finding active leak coming out the inspection plate where you access torque converter nuts. ? Borescoow camera was not much help. Finally bought a oem tools aluminum adapter for ford to use cooling system tested and it fits all my other Fords but not the Bird. WTF? Finally say f this and tighten that thing down w/ channel locks. Yeah tore the threads up but was able to pump it up and verify it leaks down. Now it seems that NOTHING is wet except the drip at the inspection plate, and the nipple. The attached Pic shows the clamp and hose is attached, but the valley is wet. Socks balls. Is there a replacement overflow that is made of aluminum?
Theres a 1" piece of tubing in the valley that goes bad. Non-metal crossober manifolds also break.
Either will leak coolant into the valley,and out the drain in to the bellhousing.
I am assuming that is the hose in the (non) lifter valley off the back of the water pump? Do you still have the NPI intake? You could replace what you have with the PI pipe and nipple combo. I believe it would work with the NPI intake. It has been so long I can't remember what the NPI stuff even looks like.
The aluminum crossover ones break too, albiet less catastrophically, where the plastic or gasket fails letting coolant seep between the seam the crossover meets. Could well be the case here since it’ll pool coolant in the valley like this as well.
If it is simply the heater return it should be as simple as replacing the coupler (hose) and clamps. The PI setup with O rings is better as @KevinVarnes mentioned and will work with the npi intake and PI universally but it’s not necessary for this fix, plus the water pump needs to come out to change the nipple
My intake is the warranty replacement from when the original plastic crossover one split. It has the alum crossover and I've had it off before due to the hose leaking in the past. I am using one of these and going w/ fittings I can count on. I'm tired of this changing shit all the time. I know it is 28 yrs old but I'm 57. I am a little leary that it doesn't fit non-PI blocks. I believe the diameter thru block is the same. If not im screwed until i can get a different one. Unless i get some threadlocker to welder in place.Screenshot_20250218-223646_Brave.jpg
My intake is the warranty replacement from when the original plastic crossover one split. It has the alum crossover and I've had it off before due to the hose leaking in the past. I am using one of these and going w/ fittings I can count on. I'm tired of this changing shit all the time. I know it is 28 yrs old but I'm 57. I am a little leary that it doesn't fit non-PI blocks. I believe the diameter thru block is the same. If not im screwed until i can get a different one. Unless i get some threadlocker to welder in place.View attachment 10476
IMO in this case I would in fact go with the O ringed nipple/PI tube in lieu of this for the same level of effort. It’s way more reliable and way way cheaper than going with something requiring AN fittings
The npi and pi holes are the same; I've swapped them on two cars. They do not come out easy,lol.
If you can smack it on the end square, it may pop out. That's what I was told, anyway.:)
The PI ones come out pretty easy with a block of wood and a hammer. All the NPI ones I have removed I have had to basically destroy to get out because they are just stamped steel. Even still it isn't too hard to do. Just beat it up.
Well there turns out to be not much left. After so many miles it looks like the nipple has given up the ghost. This is gonna be fun getting out. Probably just drill the thing out.20250222171417956.jpg
I wouldn’t drill for the risk of over sizing the hole in the block which would make you SOL. I would instead cut it past the point of the worse corrosion and use a socket over it to hammer it out. Could also very carefully cut a notch with a hacksaw blade on the inside to loosen the press fit.
That’s some crazy corrosion though, you might need a heater core sooner or later
I agree. I would try to get to some more solid material and pound the thing out. It will still take a bit to get out, bit it should come out. When I removed the one from my engine to do the PI intake swap it was a crumpled mess when it finally came out, but it did come out. I would still go with the PI stuff just because you can get the parts anywhere, but your call on that.
I have one. Not sure a 90 deg swivel will clear front of npi intake. We'll see Saturday.
NPI Intake. The pre bent hose goes up the drivers side and then to the back where it turns to go to the heater core. It is tight and I am avoiding removing the intake as it is not leaking and I re-gasketed a little over a year and half ago. I will add pictures a little later as I figure out the factory replacement which was luckily found nearby in dealer old stock. It looks as if it drives in from intake side.
So the nipple is installed w/ locktite head bolt and water jacket sealant. So the pump side is centered over the pump impeller shaft so I am wondering if this will limit flow to a damaging level?I know this is for heater so temp is what it will be.20250308_143648.jpg20250308_144338.jpg
So the nipple is installed w/ locktite head bolt and water jacket sealant. So the pump side is centered over the pump impeller shaft so I am wondering if this will limit flow to a damaging level?I know this is for heater so temp is what it will be.View attachment 10775View attachment 10776
That's interesting. Last one I installed it had a lip that seated it. And it was installed from the pump side. It didn't interfere with the pump impeller at all.
Maybe I installed backwards? It had a crimp in the middle and that would prevent it from sticking out enough to connect hose and w/o the barb?20250302_201827.jpg
Yup, you installed that backwards. The end with the lip should be sticking out into the valley.
Ok, then yes that’s correct. The picture from the water pump side looked like the lip was on that side, but it must just be the lighting. At this point I would bolt the water pump back in place and make sure it spins freely. If it does, then you’re good to go.
I don’t think that’s backwards I think it’s just that that nipple is a different design from the stock one. On the stock one the lip is on the very end on the water pump side, not in the middle
I have a block in the garage. I can post a picture if you like. In my humble opinion, while that piece "fits" in the hole. I think that is the wrong part.
I wouldn't mind seeing what yours looks like. I have 2 theories. One they made them long to be cut with a tubing cutter, or it is the wrong part that was swapped with something else as the plastic pouch was previously opened but taped shut. Mysterious that it sat on dealer shelf for 20+ years w/o a market demand. I was nervous about restricting the flow from heater circuit so I took my tin snips and cut it in a few places and flared it out to allow it to flow. It is done and works. Started it up and damned thing wouldn't idle. Rev like race car but no idle. Replaced iac w/ used one I had from pick n pull and that fixed it. Drove to work and back today (125 miles) HALLELUJAH! No wet puddle in parking space when I backed out.
Glad you got it done. Doesn't seem like a real high replacement item and figure cars that need it are around 25 years old so most have probably been scrapped so it sat. All the other cars have been PI swapped;)
I have not done a pi swap because ¹ this is my daily driver (365k original miles) ² I would find a reason to go thru the rest of the engine causing me to spend $$$ on a bunch of upgrades and ³ then I would say it is pitiful to do all those upgrades and not do a TFS head upgrade. So I tell myself see if you can get 500k out of it and then you can get what you want. I mean look at the valve that hasn't seen daylight in 27 years. Screenshot_20250315-164319_Video Player.jpg
