What causes these symptoms?
Nope. No mechanical diode.
If you don't have the mechanical one way clutch then you want to get that. That is one part to not reuse. What diameter are the locating pins on the valve body?
The stockers explode if you spin them backwards, lol.
I did indeed get and install a new one-way roller clutch, just not the one in the planetary. Locating pins? You mean the special bolts with the locator on the bottom?
IIRC, there are dowels that hold it alligned, so it can't shift. They are different sizes.
Yeah there are two special bolts that align the VB to the case. Eariler models the pins are larger than the later ones.
