That’s just the random plate I got when I got the car. The best vanity plate was ClintD got POS CAR on his $500 beater tbird! I couldn’t believe they let that one through. Before that he tried PHUCKET, which got past the computer algorithm, but then got rejected later on, presumably when a human read it.OOH! Stainless steel, electropolished looks like chrome, and I know how to do that. I'm ordering some stainless honeycomb, about 1/16"" thick or so.
Mikey, I love the plate; "89 jersey fucker", lol. DMV won't give that out. if you asked I bet. lol.
Bright, like a diamond.
Those tauruses have that weird heater hose setup. I usually wind up replacing the hose and flushing the core while the hose is off.Moved the Bird out of the garage to help a friend diagnose no heat on his 2001 Taurus with the Vulcan. Engine was not warming up. Pulled the thermostat and found it had a 180° one. Replaced it and the housing with a new OE unit and filled it with coolant. Once the new thermostat opened, I parked it sideways on the hill with the coolant bottle at the top of the system. Topped it off hot and left the cap off all night. Came back the next morning to a perfect burp. Works every time.
The engine is warming up correctly now but the heat is still blowing cold. Who wants to take bets on whether it is a clogged heater core or a dead blend door actuator?
Both hoses are full hot. The car has also been well maintained. Only has 115k and it's had regular coolant exchanges. I haven't pulled the panels yet but I'm pretty sure it's the blend door actuator. Turning it from full AC to full heat does nothing, it stays full AC cold. I also don't hear the flap moving inside the dash.Those tauruses have that weird heater hose setup. I usually wind up replacing the hose and flushing the core while the hose is off.
Gotcha. Certainly one of the possibilities.Both hoses are full hot. The car has also been well maintained. Only has 115k and it's had regular coolant exchanges. I haven't pulled the panels yet but I'm pretty sure it's the blend door actuator. Turning it from full AC to full heat does nothing, it stays full AC cold. I also don't hear the flap moving inside the dash.
(white)DRLs and constantly lit clusters are why seemingly half the late model drivers don't have their taillights on at night. Not a fan of that tbh
Alright, I'll trust you, personally, to use that as a headlight prompt, but I do not trust anyone else to lolI see your point, but I actually think of it as a reminder to turn on my headlights:
With headlights off, the cluster is obnoxiously bright, which I hate at night. It'll prompt me to turn my headlights on.
That looks great!
That looks great!
Exactly. The bad rap is purely the behind the scenes beancounting behind its adaptation, but there's nothing physically wrong with it, in fact it arguably matches the 94-97 interior design better, the older 6 gauge cluster looks like what it is, a carryover from a completely different interior.It doesn't really have a bad rap. You lose out on a couple of smaller gauges for oil pressure and voltage (or boost on the SC) that most people don't care about, and those that do will end up installing more accurate aftermarket gauges anyway. The speedo gear doesn't break like ones in the earlier clusters. Also, the SHO speedo and tach are nearly plug-and-play with custom gauge faces for the idiot lights.
It looks less technical than the old cluster but is more mechanically sound and eliminated the need for an auxiliary info center with more idiot lights in the center stack.
