Grog6
Moderator
- Harriman, TN
I used a glow in the dark paint, and added a uv led that lit the whole area. It pops. It won't photograph; it's too dim.
Instead of chlorine bleach, even though the amount you used for the short amount of time you used it probably shouldn't hurt much, I'd recommend OxiClean (sodium percarbonate) instead. Bleach is not recommended for this task because of how it weakens the fibers of textiles such as nylon or polyester.I unscrewed the floor bolt. Then I put as much belt as possible into a bucket with warm water and laundry detergent. Soaked and washed by hand. Then I rinsed several times; I added a small amount of bleach on the first rinse though some people advise against that (?).
Today I installed some sound deadner on the package tray and, inside the c pillars as much as I could reach and also on the outside and inside of where the passenger sits behind the arm panels.
The product works pretty good, no smells adheres nice no complaints so far. It’s the siless 120mil, of the 24 sheets I have 10 left.
if possible that will also be on the list for the weekend work.
I have a heat gun, is that all you need to remove the factory sound deadner? Besides the spatula
I installed the Kenwood KFC-D681C as new rear speakers to replace the Pioneer TS-A6857 speakers I had previously, one of which was I thought was blown as I described in a previous post. As it turns out though, present-day me is once again disappointed with past me; this time for a shitty speaker wiring job that was the real culprit of the speakers cutting out. It doesn't explain why the dead channel changed sides when I swapped the old speakers left and right, but that could have been a coincidence. I cleaned, re-spliced, soldered, and heat-shrunk the rear speaker wires on both sides of the car running to the amp.
Since I'm using these as rear fill, these aren't really a big functional upgrade despite being much better quality speakers. Since you can still see the speaker cones in bright sunlight through the OEM grille panels, at least they match the interior?
Today I installed some sound deadner on the package tray and, inside the c pillars as much as I could reach and also on the outside and inside of where the passenger sits behind the arm panels. Couldn’t remove the OEM sound deadner on the inside panels so I just put some around it.
The product works pretty good, no smells adheres nice no complaints so far. It’s the siless 120mil, of the 24 sheets I have 10 left. View attachment 2308View attachment 2309View attachment 2310
@Trunk Monkey Thank you for the pictures! The headliner is pretty beat up so that would give me a reason to pull it off. I’d need to buy a bit more deadner tho, I only have 2 sheets lefts. I did my doors today and forgot to snap some picture’s sorry!
I’m not sure about this, but I’ve seen on other forums people who put some sort of silicon stuffed into all the gaps on the inside of the liner, in this case it would be the perimeter of the roof and on the sides of those inner braces. Do you think this would do anything?
Just by curiosity, is the purpose of sound deadening to improve the performance of aftermarket stereo/subwoofer? Or is it literally just to make the interior quieter?
I mean it may not be the quietest car by modern standards, but I don't think it's noisy.
Mine's been buried under a boot for years.........so I'm really not sure!![]()
