Most of this happened over the last few months since the last update. I've been lax on updates, but living up to the thread title a lot of these projects I'd start, move onto another and come around again to finish, which I can't imagine is satisfying to those of you reading through all of this expecting satisfactory conclusions lol
So to start in no particular order, I posted a teaser way the hell back showing my steering rack removed. Well, I had no particular idea what I was going to do there, I actually came very close to doing manual steering, but common sense told me otherwise and I decided to pursue one of my fantasy swaps
I'm not sure how many of you know the significance of SPR ZM but this is a take-off low mile 03-04 Cobra Rack, the second best (first being 00 Cobra R) rack designed for SN95s, with a much stiffer torsion bar and better internal valving. A stiffer torsion bar in the pinion naturally reduces Assist by requiring more steering input to provide assist to the rack, and being a firmer link between the pinion and U joint provides more road feel. Neither of these benefits are possible by simply depowering the stock rack, whether it be by EVO or pump deletion.
These racks are a bit hit or miss when it comes to remans depending on who you talk to. Cardone lists a SPR ZM rack at Rockauto, but you may get a rack with the correct body with the code, but the guts inside can be from any number of SN95 Mustangs. All Cardone promises you are the rack limiters that 03-04 Cobras have(not necessary for us, see below). I rolled the dice and went used for about the same cost just to be 100% sure. All I needed to do to mate it to the MN12 was change the bushings/sleeves to the MN12/Pinto style and use the MN12 tie rod ends - inners are exactly the same, MOOG EV127 - and the steering coupler is different - triangle shaped rather than splined (I will be posting a future update showing my changes there)
These are the rack limiters. They're simply slipped over the rack gear and stop the tie rod ends from hitting the main stops integral to the rack housing.
Installed
Ooh, what is that shiny object lurking in the background? Perhaps another view is in order.
Oh yes, some of my finest sculpture to date, I don't mind saying.
So I had this wild desire to use a Mustang midpipe assembly, because everyone says they don't fit. Well they don't, but it nearly does! And as you can guess the nearly is the factory stamped transmission crossmember. After thinking up all sorts of ways to modify it, I started googling looking for ideas and found this:
X factor by American Powertrain, which are made for muscle cars with modern transmissions. I saw that they were made out of T6061 T6 aluminum, and then it occurred to me "hey I used that stuff for my K member spacers, I can make that!" And make it I did
I basically made a cardboard template traced onto paper set up to hug the floor and mount directly to the frame without bushings(which killed two birds with one stone, my old ones were dry rotted). I forget the exact measurements but I used 1/2" T6061 T6, which seems to be thicker than the X factor but I'm not an engineer so overkill is the name of the game!
Suffice to say proper tools(a mill and/or a CNC machine) would have been a tad easier and maybe less messy, but I made due.
Since both sides are identical in dimension I bolted them together during the process
Once cut out came smoothing with my grinder(s)
Checking it lines up in the car
Next is the channel aluminum(also 6061 T6, 1/4" wall)
Going together like a beefy erector set
