It a code on both banks, it popped up a day after I brought her home. I don’t have a snapshot of when it happened. I was data logging when the code was thrown though.
Cigar? Cigarette? Moxibustion? Charcoal? Old underware soaked in gas, lit and blown out?I did the cigar smoke test and no leaks. I did however find a clamp that was way up on a hose so I moved that back in a better position and placed the PCV pipe in the air inlet plumbing a little better, there was obvious oil spray on the pipe. Cleared the codes and we'll see if they come back.
Does Dorman make one? thats my only thought, or ones from other cars that are the exact same, maybe find the part number and then google it and see what other cars pop up that it says its for.Well that didn't hold at all. I installed it today, filled the coolant then pressurized with the loan a tool... It's peeing.
I'm assuming there are no other options than used junk yard at this point? In searching I found really nice polished aluminum overflow tanks, but none for our cars.
These tanks are made of HDPE and heat fusion is the only repair. The way they do natural gas pipe requires a large heating element that melts it and uses pressure to ram together when melted and is very susceptible to failures on pipe. I have ruined my original due to a oem tools adapter for a radiator tester and apparently the threads changed somewhere around '03 or '04 as the adapter works on my '13 edge, '17 f-150 and '17 Jaguar xf but not on tbird or '04 excursion. I settled for a non-sensor '95 bottle but I have a small system leak and this week I checked and found it empty. I luckily found a '97 bottle w/ sensor today and I will be using it. The non-sensor one may be the leak but I believe it is the damn motorad cap.I doubt any epoxy or tape or anything will hold because it is under pressure. The only thing that might work is a plastic welder, but I’m not sure what type of plastic that is, so I can’t say whether that is viable or not.
