Possibly. I was working on the car again today, and noticed the relay for the high side fan has melted. So that probably has something to do with what happenedAnother thought, ow about a fan on the front of the rad to push air into it?
Could they also operate as a check valve? The inline handbrake I have back feeds the main master a little, so I'm thinking I should switch my rears to one of those PVs.Proportioning valves, those two go to the rear to keep the rear brakes from locking up
You are forgetting I have a hydraulic handbrake for my drift car. It's tied into the system going to the rear brakes so I can lock them up at 80mphhand and foot brakes are cable driven, they turn a cam inside the rear diskcaliper to mechanically push the piston out.drums are similar, but drum brakes "self assist", proportionally to braking effort. (the leading pad is torqued into the drum by the friction, and shape of pad, and pivot location).
Only enough to get myself into trouble lol. Now I'm trying to see if I can do a little better with what I have, or if I need to change more things.Yes, I did not know that. You know what you're doing, lol.
Unfortunately no. If it comes to that point I'll have the guy who builds the cage do that as well.Very excited to see the rebuild and what you do. If you end up tubing the rear do you think you'll document well enough to be able to reproduce it?
Getting work like this or rust repair done these days is crazy expensive. Most people don't do it, so those that do charge enough to ensure they make good money.
Good news is you should be able to get a front clip, cheap enough, bag news is it may not be as quick as you want.
That's exactly what he said, if he was painting it he would have used bondo. To which I told him adding inches upon inches of bondo isn't fixing a car.In some ways, not necessarily in what you’ve spent mind you, at least you know what you have. A lot of times a straightened and seemingly perfectly fixed looking body looks exactly like that underneath all the mud the body shops slather over it.
Question for everyone: has anyone actually made the swap from TEVES ABS to non ABS using the "bolt in" 1991 crown Vic booster, or is it completely a myth?
