- Waterloo, Iowa
- 1991 Mercury Cougar LS 5.0
Get that couch ready.... Hopefully it's comfy. LolView attachment 6793
I'd take the front clip of mine but I haven't worked up the courage to tell the wife the entire clip will be in the basement living room to install the engine![]()
I have both, one from Harbor Frightened and Craftsman and both are about the same in quality. Check out some other brands, you would be surprised how cheap they are. I think Lowe's, Autozone, etc etc all carry them. Guess its what you are looking for.I wouldn't trust a multimeter from HF. This one is pretty reasonable and Fluke has always been one of the best: https://a.co/d/aUbxHsh
There's also this one from Klein, they have a good reputation although I've never used their meters. https://a.co/d/98w52ka
Does anyone have a picture of the door hinges with the fender removed? Is it actually possible to remove the hinge pins this way? I want to see how much working room there actually is accessing it this way.
I have had the pins and drill bit for a couple of years, I know where you are coming from.I can assure you it’s doable, it’s certainly tight and I recommend putting some thick duct tape on the door edge and pay attention but there is enough room for a cutoff wheel to make quick work of the pins.
I put off the job for years on my car because I was intimidated by it, so I certainly wouldn’t recommend this route if I had a hard time with it.
If you spend more than $5 on anything at HF that doesn't have an engine, you spent too much.For Harbor Freakshow, you might want to wait until they go on sale. I got mine when it was on sale and cost about $5 at the time. It has been reliable and well suited for what I check stuff for.
I am in my car right now, and I guess I am not grasping how you can pull the inner hinge out to drill it for the new bushing, with both the door and the outer hinge sandwich ing it in place.I can assure you it’s doable, it’s certainly tight and I recommend putting some thick duct tape on the door edge and pay attention but there is enough room for a cutoff wheel to make quick work of the pins.
So you open the door again once you have removed the pin, and just let the weight be on the one hinge while you remove the other hinge part ?On yeah you can’t do the drilling part of it with it on the car, what you do is take a cutoff wheel to the pins while the fender is off and then remove only the door half of the hinge entirety where you can drill it for the new bushings on a bench. The hinge that attaches to the body doesn’t get drilled out
I would put a jack under the door to take the weight off, or if you can get something under the door to hold it up. Unless I am completely misunderstanding what you are doing.So you open the door again once you have removed the pin, and just let the weight be on the one hinge while you remove the other hinge part ?
That fucker is definitely sandwiched between the other hinge and the door when door is closed, there is even a cutout it tucks into in the frame side hinge.
I don't quite agree with that seeing most of my hand tools and air tools come from HF. They are perfectly adequate for a DIY mechanic. The Quinn line is a bit better than the Pittsburg line but either will do the job.If you spend more than $5 on anything at HF that doesn't have an engine, you spent too much.
I understand the allure of HF and the price point their tools are at. I just absolutely refuse to support them and all of their Chinese made tools. Such a shame. There used to be a store that sold decent quality U.S. made tools for a reasonable price for the DIYer, but all of these cheap garbage import tools forced them out.I don't quite agree with that seeing most of my hand tools and air tools come from HF. They are perfectly adequate for a DIY mechanic. The Quinn line is a bit better than the Pittsburg line but either will do the job.
BUT... as far as their multimeters, I would by ANY of them. Complete garbage.
Milwaukee? Can't read the emblem that well, they are so "used". Story of my life, cordless tools about but no battery.View attachment 6979
Did somebody say tools ?? I was cleaning out my work truck the other day .. don't ask, i do not know.![]()
"You be careful out among them English!"Yes, all of my cordless tools are Mikwaukee .. bandsaws, grinders, impacts .. even a vacuum cleaner.great tools for heavy duty use. I have my own for home use also. I have probably 8 batteries on my truck .. some of them tend to go missing every time another foreman is sent out to help me on a job.
I don't get people that can't ask to use a tool and would rather just take it. Guess they have that mentality "what's mine is mine and what's yours is mine..."
Let me just say that this is a philosophical issue and we could discuss it at length and still not end up at the same place. This thread also isn't the place. I really shouldn't have responded initially or now but I just couldn't help myself.The company supplies all of our tools - so technically they don't belong to any of us. We keep our own tools on our trucks and for thr most part nobody needs to borrow anything - except for batteries.![]()
Now that, is a different situation. Thank you for clarifying.The company supplies all of our tools - so technically they don't belong to any of us. We keep our own tools on our trucks and for thr most part nobody needs to borrow anything - except for batteries.![]()
Let me just say that this is a philosophical issue and we could discuss it at length and still not end up at the same place. This thread also isn't the place. I really shouldn't have responded initially or now but I just couldn't help myself.![]()
