JJEE is also sport. But exactly zero 94-95s have either code lol
Yes. I actually run MotoMaster winter tires. They also have batteries and other automotive items. It's the Canadian Equivalent to DieHard or RoadHandler.I've never heard of MotoMaster fluid. Is that some kind of Canadian Tire house brand?
The MotoMaster Mercon V is what you want. It'll do just fine for what you need. Draining the converter is easy so definitely do it. Don't forget a new filter.Lastly, I'm Canadian and the best place for me to buy fluid is Canadian Tire, they have Motomaster fluid and im wondering if anyone has experience with it, I assume it would be fine?
so I gotta turn the engine by hand to get the tc drain plug to show, then just drain it and re plug it I guess? thats not too bad
After you drain the fluid, replace the pan with one with a drain plug for an easier job next time.
I wouldn’t run Maxlife in a 4r70. My issue is not with universal fluids, but rather that the Maxlife fluid is a much thinner viscosity than the MerconIII or V. It is compatible with the MerconLV, which is similar to the DexronVI. Putting Maxlife in a 4r70 is comparable to putting 0w20 in an engine that calls for 10w30. Yes it will work, but probably not ideal! If I were you, I would drain that out and get some MerconV in there. It doesn’t have to be Motorcraft, the parts store brands are fine as long as they say MerconV, but as good a fluid as the Maxlife is, it is simply wrong for this application.I know people have mixed feelings about universal fluids, but I've been running Valvoline MaxLife for several months now, and smoothness remains consistent (which is to say slightly better than before with Mercon V).
My experience is based on 4r70w, but generally speaking:
Tip: make sure to mark the location of the torque converter drain plug on the crankshaft pulley; it'll make things much easier next time.
- Pan drop is easiest if you first siphon out the fluid through the dipstick tube (approx. 4 quarts)
- Torque converter drain in my case filled up a 7-quart pan to the rim
- If you don't want to go through any of this, you can flush the system by disconnecting a cooler line and running it to a waste container; then start the engine while a helper pours fresh fluid into the dipstick tube
I pick them up in Windsor on my way back over the Ambassador and bring them back home to be mounted and balanced. They're made by Cooper and sold here under the Cooper name, but buying them at CT is usually significantly cheaper with the exchange rate.Also, How'd you get Motomaster tires down in the states? I'm curious, lots of people run then here as a good budget option
Or just get a $5 siphoning hand pump.
The older cars need to have the pan upgraded to the deep sump model anyway, so in those cases it's two birds with one stone.
I totally agree that I should get the deep transmission pan, however, its simply too costly for me right now to get it here in Canada, I've only ever found them in the States and shipping is brutalYou're welcome to do it however you like; to each their own.
I maintain that you'll get more fluid out with less effort with the pan having a drain plug (remove then walk away for 20 minutes while the converter drains).
This one in question is not a police package with an aluminum driveshaft.The police car driveshafts are 1” shorter than the civilian ones due to the police cars having the extended tailshaft housing on the trans. It will get you down the road, but it is not ideal.
I know the cluster backlighting is green, I’m sitting in my sable now.Quick questions while I'm at the junkyard:
On '96 Sable, is the cluster backlighting green or blue? I know it's blue on Taurus.
The '96 electronic gear indicator on floorshift Taurus/Sable, where does it get it's feed from? I know it has eight wires. '97/'98 Marks have an electronic indicator, too; how is that wired?
