		With a 7 tooth output shaft drive gear, an 18 tooth speedometer gear, 3.27 final drive ratio, that would mean the tire needs to turn 786 times to drive the car one mile
Could you explain that calculation?
I was going via the wheel circumference. For 225-60-16, I come to a circumference of 2124.973 mm. That translates to 757.4 rotations per mile.
		 but to assuage your concerns I converted my 94 from ABS to conventional using factory hardlines pulled from a 97 and it all plugged and played, I reused by previous brake hoses without issue, they threaded right into the same hardline fittings in the same positions
